Please could someone help me diagnose a miss fire, having read the other threads on possible misfires mine isnt the same symptoms.
Driving normally not above 3,000 revs and not accelerating very hard by that i mean foot to the floor max boosting, car drives and feels perfectly normal.
If i drive down the motor way and put my foot to the floor, once it gets over 2.5/ 3K revs the engine just looses boost, however ive noticed if i lift my foot gently off the pedal just slightly it picks up and can floor it again no problem, i can get it to do this every single time so is a repeatable fault.
When i checked on VCDS i had a 00561 - Mixture Adaptation 14-00 Adaptation limit ( Add ) Exceeded message. I cleared the fault and went back to create the symptoms again for about 20 mins up and down the dual carriage way. Reading back on VCDS shows no new faults.
I was told to check for a miss fire by a friend, using his VCDS on his VW golf MK 5 he can see missfire blocks when i look on my vcds i cant find any measuring blocks ( on his its 15 and 16 ) which shows the Cylinders 1 to 4 and the Missfire Count.
Other thing to note possibly is i changed the alternator about 6 or so weeks ago and had to remove the throttle body housing part a few times ( maybe 4 times ) so i have now ordered a new gasket in case thats damaged although i have used gasket seal temporarily whilst my new one arrives and it didnt seem to get any better.
So whats my next best option?
