help with electric fault throttle body
S3boyjay
West midlands
hi all, been having this issue on and off for a few months now, car goes into limp mode randomly , sometimes when driving sometimes when parking up and coming back to it, vagcom is showing 005476 throttle actuator,(fault under voltave during basic setting),
throttle body fault in basic settings intermittent 005465
angle sensor 2 for throttle, 000545 implausible signal intermittent,
01314 engine control module, check dtc memory intermittent,
can anyone help? i have checked all wiring and looks ok, sometimes it will go into limp mode then go out of it and be fine for awhile? strange one
Unfortunately, it may be time to replace your throttle body. I had to do that at ~193K km when my car was 14 years old. The part was pricey, iirc around US$500-700.
i changed the throttle body for another pre owned one and it was ok for abit then same again
Ok. How about connectors? I remember my mechanic changed those as well ...
i have ordered new connectors will try that also, i disconnected battery today for the throttle to reset then the car would not start! it was throwing errors straight away but fired up with some throttle then the errors disappear very strange,
