Hi all,
So I decided lowering my 2013 A3 8V and slammed the Eibach pro kit yesterday, unfortunately a good pack of faults appeared on the dash afterwards.
Only thing that was disconnected were the ABS sensors.
Tried clearing the fault codes in VCDS, but the re-appear right away.
I am posting the scan log
Hill hold assist
Light range
ABS
ESC
Steer assist
My rear parktronic does not work, steering wheel is super stiff doesn’t matter if I am on comfort or dynamic mode.
Frankly, I don’t get what are all those things have to do with the ABS sensor.
I’d appreciate some help and guidance on how to resolve my issues guys!
As seen from the log I got now the following fault codes:Sunday,10,April,2022,15:14:26:35672
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.4.2
Data version:
www.Ross-Tech.com
VIN: WAUZZZ8V8DA045346 License Plate:
Mileage: 210806km-130988mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 47 52 55 5F
VIN: WAUZZZ8V8DA045346 Mileage: 210806km-130988miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CRBC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H83 8125
Revision: 00H83H22
Coding: 02190012032401082000
Shop #: WSC 55711 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021DS 002013
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79F691D6C35F1587F5-802C
3 Faults Found:
17158 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:28
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 85 °C
Intake air temperature: 79 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.320 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bit 0: 0
Drivetrain coordinator: ACC fault status-Bit 8: 0
Drivetrain coordinator: brake fault status-Bit 0: 5
Drivetrain coordinator: brake function status-Bit 0: 0
Drivetrain coordinator: brake function status-Bit 8: 0
Acceleration: 0.000 m/s²
12888 - Implausible Data Received from ABS Control Module
U0415 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:29
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:29
CAN status - engine control module-Bit 0: 0
Cruise Control System (CCS): status-Bit 0: 6
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 12F162A220240A71017A060401C9294846045080608094F20279000405
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DF289DAF3633DA395-8028
3 Faults Found:
0056 - Front Right Wheel Speed Sensor
C101B 01 [137] - Electrical Failure
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 14:53:50
0297 - ROD - Unknown Error Code
- 00 [009]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:30
32993 - Control Module for Electric Parking Brake
C10E2 F0 [009] - RPM Sensor Implausble Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 14:53:50
Address 08: Auto HVAC (E87) Labels: 8V0-820-047.clb
Part No SW: 8V0 820 047 B HW: 8V0 820 047 B
Component: AC Manuell el H09 0031
Revision: 20017000 Serial number: 00000000008150
Coding: 03000104002000001000000000000100
ASAM Dataset: EV_AirCondiFrontManAU37X 008016
ROD: EV_AirCondiFrontManAU37X.rod
VCID: 35AA1922D30BEDABD5-8060
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011305301199
Coding: 04000A42C2C1227D03A44000001C07A8001C000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_010.rod
VCID: 46BBFB7D175E43206D-8012
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130206 041 0580
Serial number: 130216090347
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 A HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0002
Serial number: 20108024
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 14 02 2013 00000060
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:11
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
Component: PARKHILFE 4K 009 0026
Revision: -------- Serial number: 60831305331522
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002015
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 37A81D28CB0199B9E5-8062
1 Fault Found:
13637426 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 14:53:49
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R00FFA8
Coding: 98CCC0000C0000005C540000004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4BC4F56C3B6561C505-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 001 502 13
Component: SideSensor_Df 001 0887
Serial number: 357670000002D091AC0W
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 502 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000525207C0J
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 400 202 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502AB0F53D6210FH
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 400 502 13
Component: SideSensor_Pr 001 6149
Serial number: 35265029F0F53D62109F
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 501 13
Component: FrontSensor_D 001 6149
Serial number: 3556502AF0D3771132EG
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 601 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502C90CD5ED522D$
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 501 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502C10D46463A054
Coding: 2D2D2D
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 401 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A70F53D6442DE
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 B HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 19021304220326
Coding: A408
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 39B61116C31F9547F5-806C
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 870 B HW: 8V0 920 870 B
Component: KOMBI H24 0570
Coding: 07AD09002A8000080400EA00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 3AB71311C7128B4C8D-806E
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
Component: GW MQB High 125 1126
Revision: -------- Serial number: 0000364869
Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_008.rod
VCID: 38A91F2BCF049FBEFD-806C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 08 02 2013 11259650
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000002990142312
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 12021303110192
Coding: 00510E205C00040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3FB00D00EB39A971A5-806A
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000068447
Coding: 110000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3DB2091AF323BD6395-8068
5 Faults Found:
16135 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Motor status: 00
Supply voltage: 12.25 V
Temperature: 51.0 °C
KFC: 3F
KFA: 00 07
Environmental conditions: 5B
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 5.08797 V
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.21 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 17
12288 - Supply voltage
U1011 00 [009] - Voltage too Low
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 98
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Motor status: 00
System status: Waiting for start request
Supply voltage: 6.50 V
KFC: 30
KFA: 00 00
Environmental conditions: 4B
uAdSensI_U5VFiltered_xdu16: 5.06353 V
uioUdNotFilt_xdu16: 5.05 V
uAdSensI_SwitchedKl30_xdu16: 5.04 V
20740 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:29
Motor status: 00
Supply voltage: 12.00 V
Temperature: 38.0 °C
KFC: 51
KFA: 00 04
Environmental conditions: 7F
uAdSensI_U5VFiltered_xdu16: 5.07820 V
uioUdNotFilt_xdu16: 12.14 V
uAdSensI_SwitchedKl30_xdu16: 12.14 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 14
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:29
Motor status: 00
System status: Driving mode
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 12.30 V
uAdSensI_SwitchedKl30_xdu16: 12.31 V
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 00:00:29
Motor status: 00
KFC: 4F
KFA: 00 04
Address 47: Sound System (J525) Labels: None
Part No SW: 8V0 035 465 HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0270
Serial number: AUZ8ZAC09004KPQ
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004023
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: 75EA99E2D34B6DEBD5-8020
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 14021304080770
Coding: 005106205E00040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3EB30B05F726B368AD-806A
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000092885
Coding: 090000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 019A000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
1 Fault Found:
13705986 - Databus
U1123 00 [137] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 14:53:50
Address 5F: Information Electr. (J794) Labels: 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 864 A HW: 8V0 035 864
Component: MU-S-N-ER 039 0370
Serial number: A3F01702130937
Coding: 017303010000000021110002000A00002F0002640100010006
ASAM Dataset: EV_MUStd4CPASE 002031
ROD: EV_MUStd4CPASE_AU37.rod
Data medium:
Subsystem 1 - Part No SW: 8V0 919 866 A HW: -----------
Component: ECE 2013 --- 0021
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9CG200QDE
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000008011300010086
1 Fault Found:
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [009] - Missing message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 98
Mileage: 210806 km
Date: 2022.04.10
Time: 00:01:06
Voltage terminal 30: 12.1 V
End-------------------------(Elapsed Time: 03:51)--------------------------
Hill hold assist
Light range
ABS
ESC
Steer assist
