Help with rotor size
AyythreeAyypee
Sweden
So I am going to be ordering some new front rotors for my 2007 a3 (3 door). It is quattro with the BWA engine. I have seen the brake disc size guide posted on here (https://www.audi-sport.net/xf/threads/brake-disc-size-guide-list-oem-fit.179189/) and I have "1KJ" and "1LJ".
I have found that 1LJ is 312mm, however I am scared to place my order as I do not feel as if I truly understand the codes. Does the 1KJ code have any impact on the size of my front discs, or is it only 1LJ that I should be looking at? I would really appreciate it if someone could help confirm that this is the correct size front rotors for my car!
Thanks in advance
1lj is fronts, 1KJ rear.
If you're ordering new fronts, 1lj 312mm discs is the only ones you need to focus on
Reactions: AyythreeAyypee
