Help please! Inlet manifold/DPF issues (PPD170 8P)
Unknownthorpey
Yorkshire
Right so, I’m looking for some advice as I’m at a loss as to what to do with this one.
I have an Audi A3 Sportback PD170 which has been in and out of the garage for the past several months.
The garage has already fitted a new inlet manifold at a cost of well over £1000 (it isn’t my car - I’d have got one from Darkside if it was!)
On scanning with VCDS the car shows
012600 - Intake Manifold Runner Control
P3138 - 006 - Regulation Deviation - Intermittent.
I’ve since taken it back to the garage who are now arguing that DPF back pressure is the reason for this code appearing (the DPF was extremely clogged when I took it back admittedly)
I have successfully performed service regeneration of the particulate filter via VCDS - load coefficient is down to 1%, oil ash mass ~55g and pressure around 6mbar at idle.
The issue is the car will not passively regenerate, my theory is that it will not passively regenerate with MIL showing emissions control and engine management, this was the impression Audi had given me but I’m not sure if this is the case as the garage says not. I have been instructed by the garage the car needs a new DPF (at a cost of well over £2000, but I feel this is unlikely as the DPF will successfully regenerate when forced to (which interestingly they said it wouldn’t for them) - my issue is the original problem still isn’t sorted with the car, the whole reason for it going in initially was flashing MILs, which are still flashing. Any help would be massively appreciated as I ideally want the car to be at least working properly for a little bit longer.
Thank you!
So is that error code still present.
Dpf can be cleaned out, few companies do this.
It could be a sensor fault.
Did they perform a basic setting on the new intake, to set the points back & forth or just swap the part, did they even swap the part?
Thanks for the reply,
So what’s interesting with it is despite them claiming a new DPF is needed it has successfully regenerated and the car feels normal - what I don’t get is that they said it couldn’t be regenerated which using VCDS I have managed to do.
I’m not really sure but I’d hope they did, it does appear a new genuine Audi inlet manifold has been fitted though. I think what concerns me is the fault is still present despite them clearing it off when new part was fitted but they won’t take any responsibility for it.
When I regenerated it the figures looked pretty normal - the load coefficient was dropping gradually as it was driven back to 1% and the differential pressure also went down which makes me think it isn’t the DPF, more that it can’t regenerate because of whatever fault is still there.
Check engine 01 basic settings to see if there is a calibration for the intake & do it yourself, allot of garages can read & change parts but dont necessarily know the part needs calibration, as you have vcds, its free to check & try if present.
Iirc need to do with ignition on but engine of, but varied chassis engines have varied processes.
Thank you!
hi i have the same car had someone out today and the only code it has is p3138 intake manifold runner control on start up it’s very smokey and smells rough idling there i don’t know if someone has took the swivel flaps out of mine before i bought it
