Air suspension problem
Vance1
Yorkshire
Hi, I've just got a warning light yesterday, fault on air suspension, and today the car is very low and won't raise at all, it's showing no bars on the info screen, so gear it's the pump. Is it ok to drive cautiously till I can get to the garage, or will it get too low and cause damage? Thanks for any advice,
Vance
If the problem is a faulty compressor then google "bagpipingandy" for a compressor repair kit.
Reactions: martinivw
I wouldn't drive it tbh, its sitting on the bump stops, these are usually just foam & are not designed for constant usage so to speak, only moments of speed over bumps, driving to a garage slowly should be ok, but if its rubbing, maybe get it lifted by your recovery cover as its free no doubt & peace of mind.
