For many many years I've been wanting an S2 coupe, I had a standard Coupe 2.6E about 15 years ago but only kept it for 3 months. I also had a test drive in an S2 about 16 years ago and I so wish I had a bought one back then. Anyway over the last year I've been thinking about getting one, but it's been a tough decision as it would mean getting rid of my A6 which I got from new, was under 5 years old and had 37K on the clock and had no faults whatsoever, and I would be buying a car that would be around 25/26 years old with over 100K on the clock, and which ever way you look at it was going to need work.! I must be mad.
So with the current silly used car market I decided to sell up, I found the A6 had gone up by about £3K from the start of the year, and once all these shortages have been sorted out the used car market will take a bit of a tumble at some point so the A6 was sold. I had been looking around for S2 coupes and I knew they were a bit thin on the ground, in fact there is only 108 registered on the UK roads, and finding one in good condition body work wise, late model (95/96) lowish miles and unmodified was top of my wanted list. There were a couple of early models, and was offered a later model which was completely rotten, with almost every panel damaged and the seller wanted £15K
so that was out. Found a nice blue one but that sold by the time I had called. There were plenty of nice S2 Estates around but I've had Avant's for the last 20 years so fancied something different, so it had to be a Coupe.
A few more weeks past and I found a nice one down near Plymouth, so after arranging to meet up with @ScottD3 and I took the train down and picked up this.
It's a 1995 S2 Coupe for 106K miles on the clock, I would have preferred a black interior but the cream is growing on me! it's just going to take a lot of cleaning...
The car came with 2 sets of wheels, ones that are fitted which I just don't like and the original S2 Avus wheels which are going back on the car.
Theses are for sale if anyone is interested. Genuine Audi wheels manufactured by BBS. tyres are around 6mm looking for £450
As you can see from the brakes behind the wheel, they are very crusty and in desperate need of replacing but that is only the top of a very rusty scrap pile called the S2 running gear... More on that later.
So first job on the list was the glovebox it's been bodged at some point with a nut & bolt and did not close properly, well not without a fair amount of help..
With half the plastic missing and a rusty nut & bolt had been used as a bodge, it was at this point I figured the last owner had tried to spend as little as possible on servicing & repairs.
So a replacement glovebox has been sourced and in the time being a more simple an nicer solution was used. Simple plastic clip that was the same dimeter as the hole in the glove box, and a self tapping screw to allow the hinge to pivot.
So that was the glove box fixed.
Next up was oil & filters. Now this car you could almost class as a barn find. It was last run in 2016, then stored away, so it was in desperate need of a good service. First up the pollen filter.
I would say this is over 7 years old..
It just fell apart when removed.
Found this on the Sunday so Monday morning this lot was purchased.
So along with the new pollen filter new air filter was fitted and the 13 year old K&N (which had never been cleaned since fitted) was also dumped
Next up was to change the oil, the sump plug was just about welled on and took a breaker bar to remove it.
Looking at the service history the oil was changed about 8 years ago. With that done I moved onto the exhaust. The last owner changed for a stainless system, but they must have used the old hangers as they were completely shot.
Mid section had failed completely.
New rubbers look a little stronger than whatever was fitted before.
Next up thermostat. Noticed on the long drive home the car never got up to temp it was always around 70deg. So the thermostat was swapped out.
Picture below shows the original OEM from the car on the left, new OEM in the middle and an aftermarket on the right. For god sake don't bother with the aftermarket, it does not give the amount of flow required to cool the engine and it easily over heats. So that went in the bin and a new one from TPS was fitted.
So changing the stat was the tip of the cooling issues with the car. If left at idle for a long time the car would over heat and yet the fan would not kick in, so after a lot of head scratching and flushing the system another 3 times. I decided to replace the main rad. I found the AUX rad was getting very hot and the main rad was not getting hot enough for the temperature switch to activate as its located at the bottom of the main rad. So the old rad and coolant bottle was chucked. and new ones ordered.
So the replacement radiator fitted 80% and you cannot by new ones from Audi anymore, it was a good few mm narrower than the genuine rad so the top mount no longer reached.
Now I could have packed it out with spacers but I was in the mood for a bit of welding so off to B&Q for a bit of flat bar to extend the bracket
So chopped the end off and welded in a 8mm section
Then added a washer on the end otherwise it fouled on the lower screw
Don't laugh too much at the welding, I only whip the welder out about once a year at most!
So bracket refitted, will be getting rid of the rust once I do some other painting when I start on the front end.
Thats it for this post, more later.
so that was out. Found a nice blue one but that sold by the time I had called. There were plenty of nice S2 Estates around but I've had Avant's for the last 20 years so fancied something different, so it had to be a Coupe.A few more weeks past and I found a nice one down near Plymouth, so after arranging to meet up with @ScottD3 and I took the train down and picked up this.
