Bobby Singh's Audi S2 avant project
Great work Bobby
Reactions: bobby singh
Building oil pressure (Reaches 5 bar :) )
View: https://drive.google.com/open?id=1yw56WgzVGowkmKOaQxfdupy9vFPhEy3k&usp=drive_fs
Power steering pump bracket (supplied with the wagner)
View: https://drive.google.com/open?id=1FJOkqaCTZvyr1bhiwfzBX0-uYjkPUJM0&usp=drive_fs
The power steering bracket needed a lot of cutting to clear the BST manifold and also needed a shorter belt
View: https://drive.google.com/open?id=14I76CDz0APP5pg0lF0W3sjUprKhsk_15&usp=drive_fs
Custom ISV bracket with custom plumbing
View: https://drive.google.com/open?id=1MRl2eL4x9j8bUaFdE92zhfjMipuiOjsp&usp=drive_fs
View: https://drive.google.com/open?id=13zPB7mR9Ne7gbbdSl_dqupJy7Mt8kaSX&usp=drive_fs
View: https://drive.google.com/open?id=1SdzAq77GXjrozf18__l61tPbUf-EVGP8&usp=drive_fs
View: https://drive.google.com/open?id=1gvgyVjlPEXqsCHBD81ua42bU75k7Ew-I&usp=drive_fs
Rad pack
70mm Rad with 305mm fan
View: https://drive.google.com/open?id=1y0MpQ8_pQlaUqBVJIrFdlwvMIcbnQdQ2&usp=drive_fs
View: https://drive.google.com/open?id=17WoqdXWtuwZOvrz5zv3PNcpbssqjxM58&usp=drive_fs
View: https://drive.google.com/open?id=1vGNBp9Mykq2Yygz7Jwa87sfJ6kiIjh5S&usp=drive_fs
View: https://drive.google.com/open?id=13XTMeQA9jz9BRgHJW8m6hZS9OD-jRfQh&usp=drive_fs
Test fit:
View: https://drive.google.com/open?id=1jzDqmExUpiFonkJyBewvmcfdydGXEREt&usp=drive_fs
Fan mounted and period correct fan connector located with a custom bracket:
View: https://drive.google.com/open?id=1lzdBb1A6-q1UACFgqZP8mMfckhE5PfDY&usp=drive_fs
View: https://drive.google.com/open?id=1dr9K-Mrm9fEUe31T064gp0eH5o5bkd47&usp=drive_fs
View: https://drive.google.com/open?id=1632c0xxoUPdx45JRSR4l7J4Y0n3E0cbK&usp=drive_fs
View: https://drive.google.com/open?id=1vFz7gtiOCEx8vs28lXBWVgGw7uNKsTI5&usp=drive_fs
More powder coating
View: https://drive.google.com/open?id=1W6nybuOstPZ-WTwgcXKeokcLm4VPGFYj&usp=drive_fs
Rare alternator bolts sourced
View: https://drive.google.com/open?id=1CIHl8bKOLUxaHMWGNqDi_vpGPb5c756y&usp=drive_fs
Crank bolt tightening 450nm yep you heard that right 450nm!
Flywheel locking tool (custom made)
View: https://drive.google.com/open?id=1Ey1F33-s-bt9gzYZ531d463fNDSoDSfq&usp=drive_fs
View: https://drive.google.com/open?id=1QhndrF3Mt2SfycapdAUN5zQWD-mn9YqZ&usp=drive_fs
View: https://drive.google.com/open?id=1o2je3SQbAiX5ziaW2eo022adaJGMosIO&usp=drive_fs
Wiring extended for throttle position sensor & IAT
View: https://drive.google.com/open?id=1V0vBxgKiKSWqwX9srZOKVOJYZevUtel6&usp=drive_fs
Turbo mounted
Bobby
Set the timing for TDC in the ecu at 60deg and confirmed via timing gun:
View: https://drive.google.com/open?id=1fAFkhKauTDmjFrLGJsIWlij-o_IMF5KG&usp=drive_fs
Fresh S2 mats
View: https://drive.google.com/open?id=1dyqw1MqxyKdm1OQR0rm6hnKHYsrIEI3V&usp=drive_fs
View: https://drive.google.com/open?id=1j1IvlpU3VOQ9B66qZyH1u-SboKKbWtSc&usp=drive_fs
Noticed the front wheel were sitting too close towards the front doors - turns out all the aftermarket ball joints for the s2 have the wrong angle.
Ended up getting a pair of Audi items from Germany and now the wheels sit true
View: https://drive.google.com/open?id=19C97XgbwtEATS396S8_OvjSzzww-Yz0J&usp=drive_fs
Got the tracking done and the car now drives straight:
View: https://drive.google.com/open?id=1dOfflAIeu83S6aRMf30Ud3b-EJaxGLV5&usp=drive_fs
Custom forged wheels from China
So ended up getting some custom wheels made from China - they have the correct spec so fit without spacers or any other modifications
Forged 6061-T6
18" x 8J
ET 33
CB 57 PCD 5 x 112
I wanted a square set with max concave - after a lot of back forth with designs I went with a OEM plus wheel with 5 spokes to suit the 90's era
View: https://drive.google.com/open?id=14hPq6g4ZQIRa-pIF3oy_pCTnPx8oqf-x&usp=drive_fs
View: https://drive.google.com/open?id=1fKqtQ5giJ6QJKPL7pzcUXLkvrBTB4apJ&usp=drive_fs
All stickers refreshed:
View: https://drive.google.com/open?id=17W43UFIY5dIb-PzjUZ4vAKcgM4K2e4Wg&usp=drive_fs
View: https://drive.google.com/open?id=1lVaXAUTMoFvUZZGa3ebnP1KQtgSGpQOR&usp=drive_fs
View: https://drive.google.com/open?id=1drrB8B_QOOyRQi0-_8RwhSGi2x6ok675&usp=drive_fs
View: https://drive.google.com/open?id=1WxqmWyd5xH1wsn_qvB_cEemn-3NeiSzF&usp=drive_fs
Fuel rail issues with Asnu 1100cc injectors
So these injectors would not stop leaking plus I was having issues with using their XX O ring seals into the BST manifold.
After wasting days trying to seal the injectors it was decided to move away from their top hats and us top hats that use the C clip to hold them to the injector body & rail.
Also, it was noticed the fuel rail was not sitting true to the manifold and therefore pushing the top hats out. I didn't experience any issues EV14 injectors because they were made from one unit (no top hats to push out).
As the injectors came:
View: https://drive.google.com/open?id=1YrK_75AZ0u5i2pEyX__4HU4eKmDcIyIw&usp=drive_fs
Top hats
View: https://drive.google.com/open?id=145McoXsBKlkMKOrSq1K3QYw3nJzpN2jw&usp=drive_fs
Test fit into the rail
View: https://drive.google.com/open?id=1RkfkWnXq7jITQwajoXViJFiil09_t0im&usp=drive_fs
View: https://drive.google.com/open?id=1GHKwyz76pESJxmoMDkOLW8F28t_oJX_U&usp=drive_fs
Injector bore honing
View: https://drive.google.com/open?id=10ERXSrr8eLP7iKRIP4k04u5MWgnMDO3a&usp=drive_fs
Before
View: https://drive.google.com/open?id=1bg_AGpReBTjtGiG8XDn4oHiv8YHK1Gqi&usp=drive_fs
After
View: https://drive.google.com/open?id=1c3ovZ6QMzdmg1fCUKLhHtAFxs3w3C0ta&usp=drive_fs
Drilled and tapped the BST manifold with M6 threads
View: https://drive.google.com/open?id=1mw-NksGYcLXR8tfvmSh9j97q6y_Z07CH&usp=drive_fs
Got 20 x 20 x 65mm box section and had the centre machined
View: https://drive.google.com/open?id=1UBea0MYebP3sr_Qh1qneqSBiKKpje6WG&usp=drive_fs
Welded the box sections to the rail
View: https://drive.google.com/open?id=1_65n5RMWwqyTMyWBQdUFhzzzAULLGqpT&usp=drive_fs
To prevent any rotational stress on the rail a top support was added
View: https://drive.google.com/open?id=19kuASpzHdn4TNn9VutsrZiRI_qLFFqFF&usp=drive_fs
Tied it the cam cover bolt
View: https://drive.google.com/open?id=1-09_cQg9EcIxn3ma6t5E7hEvu2VGIO9F&usp=drive_fs
Rail finished
View: https://drive.google.com/open?id=10BCxNkL_0C0GB4qX3dKee97FS9m9-ICi&usp=drive_fs
View: https://drive.google.com/open?id=1H3uLH73Uc7bseMSLkwkwf_cIpb_ZLKaj&usp=drive_fs
View: https://drive.google.com/open?id=1MGf6iR7KMxnIkFb0ueac8UQXlFZxWB6v&usp=drive_fs
Installed
To get the connectors on I had to solder wiring on two injectors directly and then epoxy resin filled the connector hole
View: https://drive.google.com/open?id=1BRnsM0UbcVHy62nLVdR_emWE-Eel-jqk&usp=drive_fs
In the winter my plan is to install a electric power steering pump to remove the belt driven pump
Electric power steering pump - Vauxhall 140085003094
Bracket
View: https://drive.google.com/open?id=12SVOi19CuEgOSzLydFATe24JeFt58zPu&usp=drive_fs
Also, to be future proof added ARP studs:
As you can see the ARP washer is thinner than the stock one so I cut the washers of the oem bolts and used those
View: https://drive.google.com/open?id=1ZZf90mhg_6gby9d2iAzSWBNIHPdWep6_&usp=drive_fs
The adjustable gear on the inlet cam has been rubbing on the head bolt washer
View: https://drive.google.com/open?id=1B8X5npN7s27RURm0IDJPrUKvjgBL4dop&usp=drive_fs
Created clearance
View: https://drive.google.com/open?id=1sRBktFM7WBu_zEB18oUNRDE4oyhsptM7&usp=drive_fs
View: https://drive.google.com/open?id=1KrggX0XBCSVRh9DCyOsJzMNR2RDzaFvD&usp=drive_fs
