Bobby Singh's Audi S2 avant project
Head parts are finally here:
View: https://drive.google.com/open?id=1nq3CS7OoKh0VFsFeCOZVyFcPttkZHvBq&usp=drive_fs
Door card cloth
So the doorcard on the S2 have been degrading over time and the backing has been breaking away:
View: https://drive.google.com/open?id=1ppRxi-5paS_gLFm7fX6PHAu4t5B_Lt7x&usp=drive_fs
View: https://drive.google.com/open?id=1ggyLvMaM4Iac8zPDhYKQKhOGPoUQZVWr&usp=drive_fs
As you see above I managed to get hold of the origional material from Audi Tradition
Next task was to drill off the plastic welding for the door pockets
View: https://drive.google.com/open?id=1gNjWHziIQJ0B6WdXAFtVSvt12lhIIXX_&usp=drive_fs
View: https://drive.google.com/open?id=1gfBFrspNFiYVLZKdEGt25HFn0tTeASAM&usp=drive_fs
(wonder how long that gum has been there)
Ready for action:
View: https://drive.google.com/open?id=1j9oYjB4hz72A_Fg4cE-XM__8KjC1-h7G&usp=drive_fs
Final result:
View: https://drive.google.com/open?id=1JnAU2TJTnbB6SycG0-YrJoTWd1_31EyU&usp=drive_fs
Used cable tie as welding rod and plastic welded the pockets back on:
View: https://drive.google.com/open?id=1LNjBEFkZ6ezQDBtWGXa4QeYFffqNYAp1&usp=drive_fs
Bobby
Reactions: desertstorm and NHN
There's been a lot going on with the S2 in the background and its finally back from a full paint job.
Yes it was done last year however I wasn't happy with the colour match so best way to get around that is to have the whole lot done.
It come out very good and I'm impressed by the Bodyshop I used - they get my recommendation.
Nice to see the car is still solid under the body kit.
Here is a video:
Bobby
Reactions: NHN, CupraDine and Baldyone
Stunning mate
Reactions: bobby singh
Reactions: CupraDine and Sandra
Maxx datastream
So the Maxx ecu has a nice feature whereby it can datastream over bluetooth.
Bought an 8" tablet and made it removal by installing Neodymium magnets behind switch blanks
View: https://drive.google.com/open?id=1gRqddP3k_ogGG6Oiaev3-BaPxaa__n4Z&usp=drive_fs
View: https://drive.google.com/open?id=1swFsdBQdDfS7-VcEk6Qmi_88I_1LaO0-&usp=drive_fs
RS2 spec on Maxx ecu:
To get a base line of the current spec with the maxx I went back to the dyno:
Running 1.75bar (previously 1.85) and now making 370hp / 515nm (wouldn't want anymore than this on stock rods)
View: https://drive.google.com/open?id=1Kvw2-8_AfMhFka6d1XAcCWyL786TyquW&usp=drive_fs
View: https://drive.google.com/open?id=1zSqA8VT0v1lJKVLDay14CnkLSG3wgA-t&usp=drive_fs
View: https://drive.google.com/open?id=1Z-UvQlxQHZIjSroiWH94tYkM4bPX9eaJ&usp=drive_fs
View: https://drive.google.com/open?id=1N2ZtFdXDMJSzNp6YCFTMITPgB5xVWHg6&usp=drive_fs
Reactions: RyanJonS4 and CupraDine
Replacement Cam belt cover (back) - Previous one was cracked and not suitable for turbo coolant return
View: https://drive.google.com/open?id=1PKca4yzW30g0ttzYlyv5pwijRXnob4mk&usp=drive_fs
New EVAP unit
View: https://drive.google.com/open?id=1dTo7Zs46OcceYd7R7C9Mvghp1wppZ5Og&usp=drive_fs
Some AN fittings for the turbo oil & coolant
View: https://drive.google.com/open?id=1QV1z1peRQRKLLgu7AmnNQ064SJhNK44r&usp=drive_fs
Cam cover has been Cerakote (Thin ceramic coating) - Sprayed on with advantages being:
stable against UV
Chemical can not touch it (even acetone)
View: https://drive.google.com/open?id=11Mdu2ozJugNN7gCYK2RAQnb8WOU1_AFj&usp=drive_fs
High grade turbo studs and bolts
View: https://drive.google.com/open?id=18xP2aKkosei4vFUChOl0yX3U9eJFK2pA&usp=drive_fs
Been having problems with hosting pictues
So I had water coming into the boot area and at first I thought it was the rear lights and the rear number plate panel
View: https://drive.google.com/open?id=1lgVEhjHB8fehbkbMdwYYPa3uIHJkK9xC&usp=drive_fs
Roll of sealant
View: https://drive.google.com/open?id=1Yo3J2vXer6ozjcG-_K4dkOnwveekkYs-&usp=drive_fs
Lights cleaned
View: https://drive.google.com/open?id=1AaMBlqM_Bw8YG-xbYW0_XkGob8lDPxAE&usp=drive_fs
View: https://drive.google.com/open?id=1qGW_SAVQ5BbbnwRY_Dlnv7OlUy6sXRnq&usp=drive_fs
This did not fix the issue so I ended up in the boot to track down two holes which are meant to be covered at factory. I can only assume the OEM tape was removed during the repaint:
View: https://drive.google.com/open?id=1RI8gSM56wjVa3fiwilgK9csatP6MYSvK&usp=drive_fs
Sealed
View: https://drive.google.com/open?id=1h1Y7lJPCI93iWiy9rpnYemKTfVnatl2K&usp=drive_fs
During hunting the leak I found some rust (drain hole)
View: https://drive.google.com/open?id=1OE4mX1Gs9KfC2-TrA4fLEl2v7XrBHgUA&usp=drive_fs
View: https://drive.google.com/open?id=1XIu_uZAInEVHWrTsN0LuZ8uAC0OOCQ4M&usp=drive_fs
Cut out
View: https://drive.google.com/open?id=1E3ZwOb5r6jLfNaNlw7bKiWE-ubpCwe-G&usp=drive_fs
Plate made and treated the area
View: https://drive.google.com/open?id=1v1sTAcc8n6nOOYoZZ9YG6w5PZ1BewGz7&usp=drive_fs
View: https://drive.google.com/open?id=1-mUWN8ehFQ34pSDFaP0r7TzmZD9aEeCa&usp=drive_fs
While at it I waxed sealed the both sills
View: https://drive.google.com/open?id=1moQOvuGYTsS4a25I40q-btjqkTqmByPf&usp=drive_fs
Being a summer car its often on trickle charge and I wanted a more easier way of doing this.
Used the OEM gromment under the battery (so no extra holes)
View: https://drive.google.com/open?id=1QRWarDqiDl23urNqUVZlnEITd3TfMijm&usp=drive_fs
View: https://drive.google.com/open?id=10zohOt8JL0NQA0VP9KgdADSswhTCPtkT&usp=drive_fs
View: https://drive.google.com/open?id=1ZpFh5pHZj5W62uNKS3uOuLUPX_USsWvB&usp=drive_fs
View: https://drive.google.com/open?id=1sOMU1mgstPnsPKH3pW-mawDQqC4V8MZ_&usp=drive_fs
Reactions: pelhamsdetailing and CupraDine
Rear axle rebuild
This has been on the to do list for a while
Every bush has been changed (some very hard to find), sub frame powder coated, diff seals and oil changed, cv boots replaced, KW v3 suspension etc etc
View: https://drive.google.com/open?id=1CB1vLAL3fjlwgd2mHeH3ENLiqSiNLkYq&usp=drive_fs
View: https://drive.google.com/open?id=1Lbp4XYcfHv6rmlKKAHn9ZDZuFX4uBuDU&usp=drive_fs
View: https://drive.google.com/open?id=11B0GDrXSoiQeRPD3KWFed3R8aXcE6Sng&usp=drive_fs
View: https://drive.google.com/open?id=11YnFOpKGjcpUYjpmcCpsjE_sdUZA4CUf&usp=drive_fs
View: https://drive.google.com/open?id=10abDGy9NnRjsHztdCu3Wd04HYd40y1Ne&usp=drive_fs
View: https://drive.google.com/open?id=1rBLAhQ1V74pqXT5PFJtzXy71QEuy8KAO&usp=drive_fs
View: https://drive.google.com/open?id=1W982plNiEo9MdV-PVVpB9lG2S9jGkYAa&usp=drive_fs
View: https://drive.google.com/open?id=1laY8Z77LFSlhsZUW3WaiuVfVKVi9GurZ&usp=drive_fs
View: https://drive.google.com/open?id=1VjkvYG4Ykf1uFk17v2ce-yieYBUywfyi&usp=drive_fs
View: https://drive.google.com/open?id=1B3VftvIXjCeex-5ilKvtmCCAyCaGd3SC&usp=drive_fs
View: https://drive.google.com/open?id=1wTWbv06kAxktolmSlZDuOSGxAQ5OefeJ&usp=drive_fs
View: https://drive.google.com/open?id=1pPkEm7mG_3lJx2plEfwFCpHX5_JX8laL&usp=drive_fs
View: https://drive.google.com/open?id=1tbWxamuh8kZzF0XkEXjF0VbYOb4s-sOy&usp=drive_fs
View: https://drive.google.com/open?id=1AwN0fCiwUylKpVu0_AvsFjj8g6V7ffft&usp=drive_fs
View: https://drive.google.com/open?id=1NZ_cr1VfDrNXAcJjAV7DqH3dujtdbf6k&usp=drive_fs
View: https://drive.google.com/open?id=1kqGUUkiwQKbcN5dBcZxf6UHRjk1U0yXo&usp=drive_fs
View: https://drive.google.com/open?id=16V6hTXBtpu0PZMFV28Ar--EHiFUigiYj&usp=drive_fs
View: https://drive.google.com/open?id=1Z8vOQFQQxDQJ6XER8GRUBINE6mEJilt1&usp=drive_fs
View: https://drive.google.com/open?id=1Eids8-4zcEXeyxX-LgAzlcDoEOveiT21&usp=drive_fs
View: https://drive.google.com/open?id=171IMQL6KEv8owYxX1zWo05oYzTxeJpkM&usp=drive_fs
View: https://drive.google.com/open?id=191R4kZT0T5khmtdcAjmUQB6VQ4Bki3B8&usp=drive_fs
View: https://drive.google.com/open?id=1OUal-N5_KWDEOMisNFucfi_fa6HvQ089&usp=drive_fs
View: https://drive.google.com/open?id=1Iyf4Q6akqggRV_2cW7aLUdaFA10g-TUD&usp=drive_fs
View: https://drive.google.com/open?id=1Z9QcKcEBHRktRvDh293lb0H6tMgwJldW&usp=drive_fs
View: https://drive.google.com/open?id=1Uow8dHH8krtq04ut-T2h0XrKOHNnzvNQ&usp=drive_fs
View: https://drive.google.com/open?id=1WVY4uMNL4D4J_1F7S0ZfSj657nbGZzlJ&usp=drive_fs
View: https://drive.google.com/open?id=1nR7Ie6vR8380B0QOoL3kcdwzouabRFCn&usp=drive_fs
So far these KW v3's are very nice and comfortable which was my main concern.
Reactions: CupraDine and BenJee_S3
Rear abs sensors
Since doing all this work to the rear axle I had notice the abs would kick in at low speeds so decided to change the rear sensors:
They put up a good fight:
View: https://drive.google.com/open?id=1aKhH8xO4XJZMHIPITc0IuoHZ6bs0BM7o&usp=drive_fs
View: https://drive.google.com/open?id=18hjwGV_RtgaHZ0no3gzg9GkhYZtMfvfT&usp=drive_fs
View: https://drive.google.com/open?id=1BrOTJWAuGYU_59aeLqXI957aRLopxMom&usp=drive_fs
View: https://drive.google.com/open?id=1UBiVoT_leGdWFv_ddpYB9w0Hc9rLywt9&usp=drive_fs
Unpinned the plug to get the rubbers into the correct location
View: https://drive.google.com/open?id=1prG3FwNgORD-nqGjU3Wmf7uyGro4wDOZ&usp=drive_fs
Done the trick and now abs was behaving as it should
Next task bigger front brakes
Decided on:
Porsche GT3 996 caliper (larger than the C4s)
Ultra performance brackets
Merc ML350 discs - 330mm x 32
Brembo HP2000 pads
Also got my hands on cast front suspension arms
View: https://drive.google.com/open?id=1XPHJUrpL93Cp0q08CXHOXGaq4cshrnJo&usp=drive_fs
Replaced all the seals
View: https://drive.google.com/open?id=1MbWq16g4OMv5-icRNP941UOjYekYK8Jm&usp=drive_fs
Freshly powder coated:
View: https://drive.google.com/open?id=1Aky4UUN5cdBjJVAjIv7vRdl8CIr442xD&usp=drive_fs
View: https://drive.google.com/open?id=1zDtDyCHWR6l1zAN26j33_fzj_eYhtN98&usp=drive_fs
Old Vs New
View: https://drive.google.com/open?id=1Hd4I51okCJ5mbawqAygxI1DaDGaJ6C3c&usp=drive_fs
Brackets
View: https://drive.google.com/open?id=1_1ZevwqN8vDGKnPO2EjCa5U5z5xk3BUv&usp=drive_fs
View: https://drive.google.com/open?id=1Dp_ufoGcE1tzoKA-GEjUFn1Ott_muYRl&usp=drive_fs
Discs
View: https://drive.google.com/open?id=1-MQV2bUMK6fdVL4W9As9nMtGii4CpTsN&usp=drive_fs
View: https://drive.google.com/open?id=14oXoKEkKeTKt1m5i7r6xmtx3EOlYH4wb&usp=drive_fs
Pads
View: https://drive.google.com/open?id=14wDcWDaaABbarideLEwP3UcSXDzlESRF&usp=drive_fs
View: https://drive.google.com/open?id=1kvY5eo4CFEdaHYixqer7KS7FQR7DbBoM&usp=drive_fs
View: https://drive.google.com/open?id=1a0THAytunjEurLrxeT2TFrpc4WvlA2np&usp=drive_fs
View: https://drive.google.com/open?id=1LYpQAN1zFil6G8QCHkBygfIk4sSB2I0V&usp=drive_fs
All fits under the 17" wheels
View: https://drive.google.com/open?id=1TqXSsknztAmOw0-VG0oR7dTWSSELbzXK&usp=drive_fs
In preparation for servo assisted braking rather than hydro I'm currently preparing a single stage power steering pump. The dual stage pump currently supplies pressure to the brakes and steering rack. The safe pressure for the steering rack is around 110bar so using a 100bar unit is totally.
For those that are interested Back side of the pump is from a 050145155A (100bar) & Front from a 048145155F
Servo, MC etc - 4f0612105F
View: https://drive.google.com/open?id=1gOgXbBJm3sImBkTZkLXQYvcI2T4pVOxc&usp=drive_fs
View: https://drive.google.com/open?id=15TKtQcr-rVJIQ8_xgqLoA-XnhbtNqlfq&usp=drive_fs
View: https://drive.google.com/open?id=13SjNxZMU1pJOx2k2e-Gh1rvvFZOG3XDD&usp=drive_fs
View: https://drive.google.com/open?id=1lmliVUVRyIW4Hvfqqn6pf9x6kGijg2b4&usp=drive_fs
Bought this seal kit:
Next install the kit and paint the unit.
PWM & Walbro 525
Finally got around to setting up the R8 PWM unit
View: https://drive.google.com/open?id=1SrXovZLhQCfx0Uql0_yMauCJIx-_RcnP&usp=drive_fs
Pin out:
View: https://drive.google.com/open?id=1VprD9spLST7z3PRWh7w8b3biJIS-f0V4&usp=drive_fs
Used 6mm2 cable for all load terminals
View: https://drive.google.com/open?id=1RH3eL9MRWvKk-Kk4bw7DpiXIZRcNqE2P&usp=drive_fs
Perfect location next to the ABS unit
View: https://drive.google.com/open?id=12xrK9vAzpvJHmtTiskSCS-uFfzt_lquj&usp=drive_fs
Stock pump wiring was end of life
View: https://drive.google.com/open?id=1KmSMyit9o8D-ri3hVd6X_-Lk85Dy55IR&usp=drive_fs
Stock wiring Vs 6mm2
View: https://drive.google.com/open?id=1_pDhj4qiCqDzU12NJyz4xCmc8JZ2ttYn&usp=drive_fs
Stock connector re pinned
View: https://drive.google.com/open?id=14l47pid6MaeSAZujLsqIOuvF4_cwUScy&usp=drive_fs
View: https://drive.google.com/open?id=1Xxr-5wOofKD1EINLeXOY7_H2UdO0klCt&usp=drive_fs
Level sensor wires renewed
View: https://drive.google.com/open?id=1Y-E6qHereubbLS0rcbLP2SG62MM6hg2E&usp=drive_fs
After testing it I found the controller would power the pump even with the key out for around 15s
Looking at the wiring diagram on a R8 it turns out the controller is powered via relay.
So looking through some old diesel wiring looms I found a 40amp OEM relay with a holder which I repined with 6mm2 wire (used the oem fuel pump wire as the trigger)
Another great location for the relay under the PWM controller
View: https://drive.google.com/open?id=1vXEfco--BFaln1b7-vLojHuJ8OiOfRQS&usp=drive_fs
Walbro 525 pump install
The fuel pump basket was a pain to remove
View: https://drive.google.com/open?id=1u3c4LWg8LiaKCZJM9aC64STsE3yUHlvW&usp=drive_fs
View: https://drive.google.com/open?id=1KxmqNDrIQ4bUk5ZiB7CRwYKczORjMRtx&usp=drive_fs
Pump installed using a 034 adapter
View: https://drive.google.com/open?id=1GMu-a2wFE6aGzXdX3dxncARbn1S9gBx4&usp=drive_fs
View: https://drive.google.com/open?id=1HCXxS5N7FydyF5-TeqLjBDrKBtsV_dPr&usp=drive_fs
Basket installed and mapped in
The unit uses a 20hz works from 11% to 93% duty cycle
Works great and now the car can idle with just 3.4v with 35% duty cycle
View: https://drive.google.com/open?id=1sZoEb4ucZJ076ZSP0uevqeNCV23VUzAU&usp=drive_fs
Reactions: NHN
Here is a full parts lists for the PWM set up:
PWM - 4F1906093B
Plug - 6N0973755
Terminals:
963709-1 AUTOMOTIVE CONTACT, SOCKET, CRIMP, 11AWG
927833-2 CONTACT, SOCKET, CRIMP, 40A
Fuel level repair wires
000-979-135 E
Repining walbro fuel pump to oem connector 000979212E (2.5mm2)
The OEM 4 pin relay I used also used the 927833-2 terminals so buying these in bulk paid off.
One thing I would say is buy from a good source and not cheap ebay terminals.
I used https://uk.farnell.com/ & TPS
Reactions: Sandra and NHN
Nice crimping btw, which tool?
More great work.
Surprised the OEM wires melted like that tbh.
I've seen it a few times, including when I put a Walbro in one of my older machines. R8 had it in one of REperformance recent vids.
What surprises me is more cars don't go bang but I guess lack of air saves most of them :astonished:
@bobby singh Epic work mate :icon thumright:
Reactions: bobby singh and NHN
More great work.
Thanks mate - I use Toolaid 18650 kit, its not the best but does correct crimping
The OEM pump wire is now over 30 years old and the car has been running a Bosch 044 pump for the last 10 years or so.
I was reading some of the posts on the S2 forum and you would not believe some run the stock wiring with a walbro 450 at 600hp.
I've gone over the top with 6mm2 wire but its not something I need to worry about again.
Thanks mate - its slow progress but working on it between jobs
While running the cable for the PWM unit I noticed the front insulation was damp.
I started digging and found the water was coming via the pollen filter housing:
View: https://drive.google.com/open?id=1c_3RU42iFpW9LktuiIs6_YZF6jz7TLoS&usp=drive_fs
Cleaned up the whole area
View: https://drive.google.com/open?id=1--Uwt9n5WSDRReYWDpYO5G-9RzBV8cCq&usp=drive_fs
View: https://drive.google.com/open?id=1oLUcuaWXlsOdlMUW55fkyMxkUKsKJbTc&usp=drive_fs
The seal itself had been overlapped on one side and off course its no longer available
So used 3M sealant
View: https://drive.google.com/open?id=1l4PY7tVtJoj87Pw68UiD9HQtSHLDd0F3&usp=drive_fs
View: https://drive.google.com/open?id=1Nb09sW0BHqthU_esgg8X3XZacOLbNDas&usp=drive_fs
View: https://drive.google.com/open?id=1zdlmUAsoF89DnIHXzTqwOSm7kzTExPIO&usp=drive_fs
Whole area was then sealed with Dynax-UC clear wax
Fuel Rail pressure sensor
Next task was to install a fuel rail sensor to enable fuel tracking:
Had mount machined out of stainless steel and I used a Mercedes M10 x 1 fuel pressure sensor from their diesel application - rated to 11.5bar
View: https://drive.google.com/open?id=127dOmBKIHQYegvoCENlKJbnoqUeypPju&usp=drive_fs
View: https://drive.google.com/open?id=1AOEbLrZgdVxLEfiLM_hQ6SXDNnwBAyPu&usp=drive_fs
View: https://drive.google.com/open?id=1BSWalvUo9S7jiypYcxGqKgAa5nzr-3vG&usp=drive_fs
Powder coated
View: https://drive.google.com/open?id=1aozcBaWfSq4iFSufFPPGQZJcrAxMgKWy&usp=drive_fs
View: https://drive.google.com/open?id=1RUg2C62Ib9vFztUGwNdcE5mpkHGxKaCh&usp=drive_fs
Perfect fit:
View: https://drive.google.com/open?id=1RW6dZrTSbCGo3G8dC8oOYs0WWff9RPcb&usp=drive_fs
View: https://drive.google.com/open?id=1q3RDIy_x4p6CPUEdAwOIpOIlgvaH97f9&usp=drive_fs
View: https://drive.google.com/open?id=1Wtv_uhdivmlwGhgi8kV712JtG9NIYsEI&usp=drive_fs
Got exhaust manifold pressure sensor mounted from a PSA rated to 6 bar - used the psa bracket into brace
View: https://drive.google.com/open?id=1p7Z1PNv0u0SkLXczMMGqh8VWcjaxG3fS&usp=drive_fs
Managed to get my hands on new oil cooler - might not be man enough for the new engine but for short weekend blasts hopefully its ok.
Reactions: spartacus68
Engine work has finally started - Old engine removal:
View: https://drive.google.com/open?id=1Z7OAHwTAOlgu1luJQLYxz0_W_ASTYt0P&usp=drive_fs
View: https://drive.google.com/open?id=1OuJglNIYf-3Y_ygEmuQELe6MqFt0BW-2&usp=drive_fs
View: https://drive.google.com/open?id=1bh4wWrTN5ZgUMmKgqHfpRrSET_3Q9eJb&usp=drive_fs
View: https://drive.google.com/open?id=1BT9XHRwml6_kHcXD48OUmXBjY0p2hEoN&usp=drive_fs
View: https://drive.google.com/open?id=1KN5xVzYt2IQKs3l1DjLg2gLS7yzX23rO&usp=drive_fs
View: https://drive.google.com/open?id=18afiubSMjP2gGpeXhYSvY29JBvGfoOsb&usp=drive_fs
Engine bay washed and detailed:
View: https://drive.google.com/open?id=1DkTPf5GTmyrP9sfImpwgXdhdyYErZKoh&usp=drive_fs
Sub frame
View: https://drive.google.com/open?id=1ilkxMYj6boAkviUw9cBR_n_rdq6Jw1Nh&usp=drive_fs
View: https://drive.google.com/open?id=10Arj_7TUIIwAUWwpjVyrMXsqARLSeE9T&usp=drive_fs
Oil cooler duct powder coated
View: https://drive.google.com/open?id=1duuF7L1B8Eq2j5INJB4td4lzz5wtXUj6&usp=drive_fs
Replacement engine mounts
View: https://drive.google.com/open?id=1QIJ2GfEh_SFnIFxSZWoGlNEIaz8Ul9QU&usp=drive_fs
Metal face clutch release bearing
View: https://drive.google.com/open?id=1XRzQ-_u-osxrL75fv9oSXPYLIoRrZ7EL&usp=drive_fs
Old clutch line remade
View: https://drive.google.com/open?id=1YSfjlN9LoEyawCi_w87yfHW0F5Hy-__D&usp=drive_fs
View: https://drive.google.com/open?id=1BI5bbrN3AqwQldfsx0AoD7j1vu9PaIl7&usp=drive_fs
Water manifold:
View: https://drive.google.com/open?id=1-t5mPMTGu4MKO0vCXHuk_hHnr0b04YpF&usp=drive_fs
View: https://drive.google.com/open?id=11EmnKnHMF6Y1yOVAeI23m9kgUk-zn0Xi&usp=drive_fs
View: https://drive.google.com/open?id=1E5_xzBgoAsBk0d1-Iz7wULH1hAAbmFu_&usp=drive_fs
Track rod arms
View: https://drive.google.com/open?id=14uThNeKslWOmOcIcU4vzo7wAXStjPg8C&usp=drive_fs
View: https://drive.google.com/open?id=1E2E8-F2JiIgl-wcIGYhvB4J1VOxzwBmd&usp=drive_fs
Adjusters with 17mm hex compared with the 14mm stock
View: https://drive.google.com/open?id=1H1fLFctQLxpl5_5xGZZBBs_s1fRTHO0G&usp=drive_fs
Aux loom recondition
View: https://drive.google.com/open?id=1WV2JveWVS6y3fOEmWbrgDngJbCyiL2jP&usp=drive_fs
View: https://drive.google.com/open?id=1r1XQt5Pd1yebDOj9HFdxUNvs6bxBLNBS&usp=drive_fs
Steering rack rebuilt
View: https://drive.google.com/open?id=1AIx8u933WMEvNhystZb47gCi-QJ_s2vm&usp=drive_fs
Front hubs, dust shield, brackets etc all powder coated
View: https://drive.google.com/open?id=1ED0NXzbWvxgYrZ4wALCwUWlJpasuji1b&usp=drive_fs
SKF bearings installed
View: https://drive.google.com/open?id=1xWNRP3kCQFL5XUxt6AJRZmhh37-NqR2d&usp=drive_fs
Gearbox oil changed and cleaned up
View: https://drive.google.com/open?id=1U3PEeG8_icxq742OvGGqBV6HmUEZ4x5A&usp=drive_fs
View: https://drive.google.com/open?id=1ocIGgSxs1hGFcXnY6N5fkr1JyeLalvy1&usp=drive_fs
Flywheel with 60/2 trigger built in
View: https://drive.google.com/open?id=1o7hwNpQGJUUnP4oSqPWlvHpXnDJLuchm&usp=drive_fs
View: https://drive.google.com/open?id=18Euxc8CYQLQH-IYB5FvKQJzaKOi9jhEh&usp=drive_fs
All new suspension bolts:
View: https://drive.google.com/open?id=13hicuUUzs6fKfeNxzccRvmI_UI4aZr7R&usp=drive_fs
For the last few weeks I've wire been brushing, cleaning etc etc all the small parts of this engine but the task continues.....
Reactions: alps26, WilkoS5 and Sandra
Excellent work as always Bobby
From hydro to Vac servo
I wanted to get rid of the hydro servo as parts are hard to come by and its a complex system to maintain.
I used kit from https://www.ultraperformance.co.uk and used a servo from a Audi C6:
View: https://drive.google.com/open?id=1fHPhxgihgQJgg9RVxfV9nuMI83phCV7q&usp=drive_fs
(Got it wet painted)
Stock set up
View: https://drive.google.com/open?id=17C3uTK9hrDlR-ki-uChdfyh80k9EDYu_&usp=drive_fs
View: https://drive.google.com/open?id=1y37NjCYI1MRZU2EPWL2bt5K--GSp7pjL&usp=drive_fs
View: https://drive.google.com/open?id=1_nj3Uo8mqdYW1zbLiwLBO3LErL3i5hFv&usp=drive_fs
Adapter plate mounted - noticed the cross brace needs cutting off as well as the fuel line holder
View: https://drive.google.com/open?id=1WsiG1nZj_0l-lDPgTNuked55Hf5pk5KR&usp=drive_fs
View: https://drive.google.com/open?id=1jenNZDVq31dcLLEFnnRvk8rnBedgCkZY&usp=drive_fs
Cuts made and painted
View: https://drive.google.com/open?id=1xeJed4FKPafEo-58gGKICt6zWTfpp-zN&usp=drive_fs
Servo fits but the fuel lines are in the way
View: https://drive.google.com/open?id=1dYa9_Se0PuOZJdUK9mDlcVwZJms6P-Tl&usp=drive_fs
Cut the fuel lines behind the heat shield under the firewall
New fuel lines (an6 from BMRS)
View: https://drive.google.com/open?id=1sWomMhBpRB3QFDCfBncuEk6VJf1UuFo9&usp=drive_fs
Wiring bracket needed cutting short too (was coated afer)
View: https://drive.google.com/open?id=16OZVK5uuEMFRTGoLM2JmZVs2vljwQxzd&usp=drive_fs
Next AC line needed modifying to clear the servo
View: https://drive.google.com/open?id=1YXkOUXwrWGSkk70BR9lS51I58k0btWjw&usp=drive_fs
40mm cut out where the G clamp is
View: https://drive.google.com/open?id=1N3SzgDyGcNLZPZa6Zsgfk-K-a02afE4m&usp=drive_fs
And then the bolt in front of the servo needed 60mm extending
View: https://drive.google.com/open?id=1BJ1pq9tQKrSb2yRKUdsuPsxDLPKJ3m7j&usp=drive_fs
View: https://drive.google.com/open?id=1bkW-3eSWP75y_Gs6M0QKIDRX0knKwzAJ&usp=drive_fs
View: https://drive.google.com/open?id=1a44uSdEbX1LfbBHtHAGxYKZTa7rpCCFE&usp=drive_fs
View: https://drive.google.com/open?id=1ybtA3MLtamBgB9Ytr3xW8KYlTToZpLJe&usp=drive_fs
Ac line complete with all new seals
View: https://drive.google.com/open?id=18-RBcXDtQ5x2KqMti8-zoy2MPDieZ6oK&usp=drive_fs
Brake lines extended for the new master cylinder & heat protected
View: https://drive.google.com/open?id=1t0EXB74NaQpQeNLLpQsiDq5Bpv9DWfV4&usp=drive_fs
Heat shielding made:
View: https://drive.google.com/open?id=1IEGNPeR44FtAzNHW3oItzaAh-whVSMmP&usp=drive_fs
View: https://drive.google.com/open?id=18R71UHOTiYIg1bEIBJ4LDfM7nhJHj6R3&usp=drive_fs
View: https://drive.google.com/open?id=1PT2_ppvYm8f59-SdWHoB7yzvvW9ZYGOx&usp=drive_fs
View: https://drive.google.com/open?id=1Jlq80O0A9e7mIZDc2vcgg2jfZKYPKxYO&usp=drive_fs
Extra wires ran into the engine bay via ecu loom
View: https://drive.google.com/open?id=1r8IwYrtDHYD7ANRAcVotA7L1t_-wJAO9&usp=drive_fs
Reactions: NHN
Man this cars epic, the work & atd is great bud.
Thanks - its getting there slowly
Finding time to do my own car is always challenge as customers cars have to come first.
Do you run your own place for clients also, as be good to know when I'm asked by my clients if there's anyone out there.
Edit, found your yt channel lol
New heat shield nuts
All air con lines redone with fresh hoses
Alternator seen better days
Rebuilt
Bobby
Those shield nuts look much better quality than the ones of today that corrode to feck very quickly.
