Hi, I'm trying to code HUD sport display on my 2017 S4 but my VCDS doesn't have the map for controller / doesn't offer experimental view because i have an older cable (even though I am still able to access and code controllers) - can someone kindly help me with long coding details for the following?
1) Enable the sport display (lap timer, gear, oil temp, etc..) in the HUD If you have an A or S model with HUD
NOTE: You might need to enable the Laptimer (see “Enable Laptimer shown in DIS”) before this can be coded.
Description: Enable laptimer function in VC / DIS
Once this is done, i will share details all of all tweaks i have made via VCDS on my 2017 S4
- 82 - Head Up Display
- Long Coding
- Change “Laptimer_activated” to “available”
- Press and hold green check mark to save.
- 17 - Dashboard
- Long Coding (Bytes+Bits)
- Select Byte 1
- Enable Bit 3
