MMI Problems help!!!
andrew birnie
Hello all, hope someone can help, my MMI started playing up yesterday, first noticed Bluetooth wasn't working, then a myriad of problems started ..... mmi says aux input being used ..its not .... screen volume button froze with no sound through CD or radio .... when the car is off and locked the mmi is still on won't switch off ..... in the settings the the date and time can't be reset or can I update the system.... also in any of the settings that says to switch on the ignition I switch on ignition and it still says switch on ignition ......
Please help
If you have a car with the control dial, try rebooting by pressing the dial whilst pushing the two shiny switches up, all at the same time. It's like a ctrl-alt-delete. Dunno how to do the equivalent of this on the newer touch-screen downgraded cars.
On the touchscreen version press and hold the on/off/volume switch on the centre console until the screen goes blank.
Thanks man but done this a hundred times
Try a factory reset, it's in one of the menus somewhere. But, I suspect you've got a faulty unit there, too many things going wrong.
Definitely a fault somewhere I think, the factory reset option says its unavailable as is the date and time setting, everytime I switch the car on or reset the mmi (2 button up press main button at same time reset) the mmi clock starts from zero ‍♂️♂️ cheers anyways man
13
867
