Help ,Help , Help, Issues after water pump and stat change
Darren McDonnell
Wirral
Hi All I have just had to change the water pump and stat on my Crec 2014. I had to take the charger off to do it and now after putting it all back last night there is issues
the car struggled to start and there is faults showing. the car wont rev and has a rough idle.
I also had to change the cores inthe super charger so the throttle body has been off but all this is basic and I didn't expect it to not run once back together.
I did wonder if there was a battery issue so have had it on charge but still the same. I get a message that the tyre pressure monitoring system is faulty but i havent touch this as well as a message about the diff again not touched. the car has been sat since Easter when the stat broke.
Below is a full scan from last night and also a couple of small scans after i cleared them.
Sorry for the long post
scan to follow (to big)
VIN: WAUZZZ8K3FA032593 Mileage: 191910km-119247miles
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 8K2 907 551 A HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0006
Revision: --H10---
Coding: 0A2500340547010B2800
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30TFS0218K2907551A 003002
ROD: EV_ECM30TFS0218K2907551_003.rod
VCID: 3169A0C36029530EB4-8064
18 Faults Found:
14944 - Magnetic Clutch for Supercharger
P25EB 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2021.04.03
Time: 15:58:55
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 11.679 V
Unlearning counter according OBD: 40
Engine status: Stop
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
Charge press.: average: 1.032 bar
Oxygen sensor before cat bank 1 (LSB) voltage: 1.997 V
FAC_TPS_1_SAE: 99.609375 %
FUP_H_SAE: 980.0 kPa
21041 - Engine Oil Bypass Valve
P05E8 00 [096] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2021.04.03
Time: 15:58:55
Voltage terminal 30: 11.660 V
Engine status: Stop
T_AST_SAE: 0 s
FUP_H_SAE: 990.0 kPa
22503 - Intercooler Temperature Sensor (Bank 1)
P007B 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 12.128 V
Engine status: Stop
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
FUP_H_SAE: 320.0 kPa
22504 - Intercooler Temperature Sensor Circuit Bank 2
P00A1 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
19472 - Intake Air Temp. Sensor (G42)
P0113 00 [032] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
15313 - Engine Coolant Temp. Sensor (G62)
P0118 00 [032] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 11.894 V
Engine status: Stop
T_AST_SAE: 0 s
19481 - Manifold Pressure / Boost Sensor (G31)
P0238 00 [032] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
19483 - Manifold Pressure / Boost Sensor 2 (G447)
P0242 00 [032] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
25277 - Intake Manifold / Boost Pressure Correlation
P006C 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2021.04.03
Time: 15:58:54
Voltage terminal 30: 11.718 V
Engine status: Stop
Engine status: Stop
IGA_IGC_SAE: 0.0 °
19501 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0108 00 [032] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
19506 - Intake Manifold Flap Position Sensor (Bank 2)
P2019 00 [032] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
23151 - Control Circuit for Intake Air Regulating Flap
P10A3 00 [096] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2021.04.03
Time: 15:58:54
Voltage terminal 30: 11.738 V
Engine status: Stop
T_AST_SAE: 0 s
23159 - Position Sensor for Intake Air Regulating Flap
P10A5 00 [032] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
19546 - Thermostat for Cylinder Head
P199E 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2021.04.03
Time: 15:58:55
Engine status: Stop
T_AST_SAE: 0 s
21608 - Sensor for Ambient Air Temperature (G17)
P0070 00 [032] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 12.011 V
Engine status: Stop
T_AST_SAE: 0 s
FUP_H_SAE: 1000.0 kPa
16469 - Throttle Actuator Control Circuit
P2100 00 [167] - Open Circuit
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
T_AST_SAE: 0 s
15337 - Throttle Position Sensor (G69)
P0123 00 [167] - Signal too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
TPS_AD_CDN_MIS: 0
Throttle valve angle: specified value: 4.8 °
Throttle valve angle: 94.394 °
Throttle valve position 1: 4.990 V
Throttle valve position 2: 0.000 V
Throttle valve: activation: 0.00 %
15340 - Angle Sensor 2 for Throttle (G188)
P0222 00 [167] - Signal Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191915 km
Date: 2000.00.00
Time: 00:00:00
Engine status: Stop
TPS_AD_CDN_MIS: 0
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K0 927 166 HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H02 0004
Revision: --H02---
Coding: 000001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 72EB6FCFA5AF28160D-8026
1 Fault Found:
8448 - Implausible Data Received from Engine Control Module
U0401 00 [109] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 191915 km
Date: 2021.04.19
Time: 20:32:12
Engine speed: 1526 /min
Transmission input speed: 1526 /min
Transmission output speed: 0 /min
Engine torque: -12 Nm
Transmission fluid temperature: 20 °C
Accelerator position: 38.8 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 14.000 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.918 V
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Revision: -------- Serial number: --------------
Coding: 295DCE01
VCID: 09192823A0394BCE5C-805C
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 15:58:56
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0022
Hex Value: 0x3392
Hex Value: 0x0000
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.19
Time: 20:29:21
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x0782
Hex Value: 0x000B
Hex Value: 0x468C
Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.19
Time: 20:29:22
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x2282
Hex Value: 0x000E
Hex Value: 0x508A
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 JE HW: 8K0 907 064 JE
Component: BCM2 2.0 H14 0650
Revision: 00002001
Coding: 01B14040000000000000
Shop #: WSC 06325 000 00000
VCID: 7CF741F7FFEB6E6657-8028
Subsystem 1 - Part No SW: 8K0 959 754 BH HW: 8K0 959 754 BH
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0514000093476003
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 0214000132480016
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 14:15:39
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AP HW: 8K2 820 043 AP
Component: KLIMA 3 ZONEN H04 0122
Revision: D0000000 Serial number: 01160720140354
Coding: 6624028080
VCID: 77FD5EDBC6CD4D3E3A-8022
3 Faults Found:
01230 - Left Footwell Vent Temperature Sensor (G261)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 08:14:45
Freeze Frame:
Temperature: 6.0°C
Speed: 0.0 km/h
Voltage: 11.80 V
00457 - Central Electronics Control Module / BCM (J519)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 15:58:54
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.19
Time: 20:29:20
Freeze Frame:
Temperature: 13.0°C
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000858586702
Coding: 260000118234AFE22F8140C000001D0D4F9DC30A27090201000008004400070200020024000000
Shop #: WSC 06335 123 12345
VCID: 7AFB47EFF5DF505645-802E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110714 H06 0080
Serial number: SWF14077115700
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22911833
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001607140798
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: B1880C37000000000001
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 25
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 14:15:13
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 15:58:58
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 B HW: 8K0 907 561 B
Component: ACC3 H11 0100
Serial number: 00000000000000
Coding: 003352
VCID: 3169A0C36829530EB4-8064
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 15:58:55
Freeze Frame:
Temperature: 14.0°C
Voltage: 11.65 V
Hex Value: 0x00DE
Speed: 0.0 km/h
Lateral Accel.: 0.00 m/s^2
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 125
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 15:58:55
Freeze Frame:
Temperature: 14.0°C
Voltage: 11.65 V
Hex Value: 0x00BD
Speed: 0.0 km/h
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.19
Time: 20:29:21
Freeze Frame:
Temperature: 14.0°C
Voltage: 10.37 V
Hex Value: 0x00C0
Speed: 0.0 km/h
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 983 B HW: 8K0 920 983 B
Component: KOMBIINSTR. H35 0564
Revision: 00200000 Serial number: ZCK57EX5F
Coding: 33EF0900DF012600010400
Shop #: WSC 06325 123 12345
VCID: 3467A9D7973B6626DF-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 14:15:15
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z147110F51
Coding: 80CF07FF00
VCID: 4C97D137EFCB1EE6A7-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 7343774003
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 14199000853021200410
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.10
Time: 09:25:49
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.60 V
Count: 16
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H15 0100
Serial number: 001007140001003
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F6DA6BB761D45FEA2-807A
1 Fault Found:
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 165
Mileage: 191915 km
Date: 2021.04.19
Time: 20:29:22
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0341897905
Coding: 011F062280B908808330013680000047
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 23
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 14:15:39
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000406768
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7B87EFBD5F905605-806E
1 Fault Found:
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 165
Mileage: 191915 km
Date: 2021.04.19
Time: 20:29:21
Voltage terminal 30: 11.2 V
Internal Fault ID: 188
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109G00E7951329
Coding: 010103010000000001
VCID: 2D51BCB3741137EE90-8078
1 Fault Found:
02984 - Connection between Impedance Converter 2 and Window Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 124
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.03
Time: 08:15:09
Freeze Frame:
Voltage: 11.80 V
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 60021470900100
Coding: 0023201
VCID: 377D9EDB464D8D3EFA-8062
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 165
Mileage: 191915 km
Time Indication: 0
Date: 2021.04.19
Time: 20:29:21
What have you unplugged as for me its a connection or fuse problem, too many electrical errors to be mechanical.
Reactions: Darren McDonnell
I'll need to have good look over it again tonight.
I had to unplug a few parts to get the charger off.
What made you change the coolers in the charger unit?
while it was off it made sense when you saw them.
Thanks for that, did you get them OEM or aftermarket? Also got a P/N, ive got my charger off currently so may change mine.
I went for aftermarket, You would need to check the part number on yours as they are different in the B8 to the B8.5 Crec. Its on the back of the cooler by the bleed screw
You have faults timestamped 2021.04.03 15:58 with voltages as low as 11.66 and then you have ones with a default reset timestamp and the voltage is barely over 12. Then I see some on 2021.04.19 with mostly low voltage but one shows 14V. How do these dates correspond with work you have done? As you know these cars can have false DTCs with low voltage. You need the power to be healthy before you can rely on scans. If your battery is on its way out then a charger might not be able to achieve that because there is too much current going into the battery and not enough for the control units.
Thanks pal. I’ll sort the battery and then see where am at.
So Update.
New battery fitted and the missed throttle body cable Doh, That what happens when trying to do it of an evening after work .
the car now starts and drives but I do have a message saying intake flap bank 2 stuck closed.
I have done a vacuum test and it is connected and i can hear something happening but cant tell by how much.
This is the only intake manifold i took off to do the job is there a way that they should be reinstalled i did check that it opened but only by hand/ fingers.
whats the next step?
Cheers Lads
Not as much fun when its your family car.
Reactions: spartacus68
update no2. a Quick google and i had the answer I had made the amateur mistake of not opening the flaps before fitting the manifold.
Charger off and on again just need to fit the belt and we are good to go.
This is the first time i have had to work on the engine other than basic service etc so its a steep learning curve.
I can take the super charger off pretty quick though :)
Reactions: pelhamsdetailing
Cheers, will check. Mine is also CREC so ill see what the state of them is.
I went with. Mahle ones. At about £150 each.
Oem where £350.
Stock is a problem with most places
also when it arrives check the water pipe end is nice and flat. I had one that had a small dent and had to be returned.
you may also want new prongs for the water pipe. I got these from Audi with the water pump and stat.
Reactions: roberto.
Glad to see you got the issue above fixed. My coolers look to be in good shape so going to leave them. Stat and pump being changed on mine today though.
