Squeaky window seal
AlS3BE
Edinburgh
Hi guys
Looking for some recommendations.
My rear passenger side window squeaks when going up or down.
I have tried cleaning the window, cleaning the rubber with apc as best as I could and it still does it. Might go away after a while but comes back. Was thinking some grease on the rubber but don’t want greasy windows.
Any suggestions appreciated.
No idea pal, I'd try rain repellent, works a treat on wipers
I’ve got a sneaky feeling it could be spray wax/sealant that’s actually causing it.
Will try a glass polish and try and remove it what’s there and see if it helps.
Hi guys
Never had this issue, but I would try some 'WD-40 specialist high performance silicone lubricant' just on the rubber seals. Spray until damp on a cloth and wipe the seals with the lubricant cloth. Open & close a couple of times and then clean any residue grease off the windows. Then glass polish.
Or use some Gummi Pfledge on the seals.
Reactions: AlS3BE
