SSS3 said:
How exactly do you get a good 0-60 ( 0-100km/h ) ?
I've tried a few tactics and all seem to end in clutch slippage or bogging badly ?
my best time i ran last night was a 13.9 and 170km/h exit on a rather bad bogged launch ;(
Cheers :>
Hi Way ... great to see you on the audi-sport forum as well
Seems like you had a good run with the 13.9, but I agree, a mid 13.5 should be achievable with a good launch.
I have another take on the matter which goes something along the lines of "less rev's on the 8P S3 is actually better".
My logic is that the 2nd generation haldex is much more sensitive in picking up wheel slip - thus you don't need to dump 1000's of RPM onto it for good off the line traction.
Whenever I get "too brutal on the revs" and "dump it too suddenly" I get a severe case of the "bogs".
But in the past few days, running a new map for octane boosted fuel, the power has been rediculous and this method is simply not working.
Enter the "gentler" approach:
Last night tried a few launches with only about 3000 to 3400 RPM dialed in, and then a quick, but controlled slip of the clutch. Well - launches were perfect, with instant traction and I was quickly through 1st and into 2nd and 3rd.
I'm going to try this a bit more and then try to confirm if there's potential in this method.
