Look what I found today whilst routing the cables for my rear camera and rear PDC sensors through the boot, My car has done 1600 miles and has seen very little use, especially in the boot area its like new, the wiring loom for the boot lamp units, boot release and N° plate lamps is clipped to the swan neck hinges and is chaffing on the bolt heads which fix the hinge in position to the body shell.
this may be the cause of some strange faults in the future if left to its own devices, at least it should be in the dry. I was looking closely because I thought the loom was being tortured the way its routed at the hinge and the range of movement it is subjected to each time the boot is opened and closed.
