Fuel flap actuator - VCDS fault code
besters
Nottingham
Hi all,
Audi A1 2016.
Need a bit of help, my daughter has a fault on the fuel flap actuator or at least I think that's what it is rather than wiring. The fuel flap doesn't always open on the press of the key fob. Could it be a wiring fault?
Anyone had this before?
VCDS reports the following fault code -
00332 - Control Circuit for Tank Flap
007 - Short to Ground - Intermittent
Dave
Quite common being the actuator on the fuel flap,as my mate (AA Roadside) seen a few where they don't open all the time or just fail.
Its a common code across the whole VAG range, and I've seen a few, so I'd change it before your locked out of fuelling
She's had it changed under the warranty so all good.
Thanks for the reply.
