Lighting Faults Help Please
Dadar
Horley
Hello to you all I am after a little help please with a lighting fault on my A5.
I was driving today and flashed another driver and all of a sudden I had lots of bulb/light failure messages come up on the DIS.
Right hand DRL not working
Left hand indicator/Fog Lamp and main and dipped beam not working.
I have scanned the vehicle and here are the results
Would very much appreciate some help on these please.
Have checked all fuses and none have failed.
Code:
Sunday,22,November,2020,18:16:15:38628
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 20.4.2.0 HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ8T2EA012133 License Plate: PA11GUL
Mileage: 68920km-42824mi Repair Order: Lighting faults scan
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F
VIN: WAUZZZ8T2EA012133 Mileage: 68920km-42824miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CNCD) Labels:. 06L-907-115-V1.clb
Part No SW: 8T2 907 115 HW: 8T2 907 115
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 1A1900322327010B2000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TFS0218T2907115 001004
ROD: EV_ECM20TFS0218T2907115.rod
VCID: 75B7E230154858E3715-8020
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CD HW: 8K0 907 379 CD
Component: ESP8 quattro H09 0050
Revision: -------- Serial number: --------------
Coding: 30154401
Shop #: WSC 06325 000 00000
VCID: 7DA7FA102DF800A3395-8028
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 218
Mileage: 68926 km
Time Indication: 0
Date: 2020.11.22
Time: 18:09:52
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x0010
Hex Value: 0x1094
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 03B04040000000000000
VCID: 79AFEE0039D03C8315D-802C
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0813000089166008
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2313000118606014
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Component: KLIMA 3 ZONEN H04 0121
Revision: D1000000 Serial number: 01020720130594
Coding: 642602C000
VCID: 3A2D310C7C56F79B5C7-806E
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000639432602
Coding: 260000108034AFE01481400300001D0D419D038827090201000008004400030100000024000000
Shop #: WSC 06325 123 12345
VCID: 78A9EB0402DA258B6A3-802C
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 020713 H13 0080
Serial number: SWF13070025424
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21474630
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002206130833
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 2B9884B6000000000001
2 Faults Found:
01516 - Terminal 30; Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 2
Reset counter: 218
Mileage: 68926 km
Time Indication: 0
Date: 2020.11.22
Time: 17:04:09
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 8
Reset counter: 218
Mileage: 68926 km
Time Indication: 0
Date: 2020.11.22
Time: 16:28:24
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H47 0610
Serial number: 003KFDB0KHCP
Coding: 30533933363030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 48C95BC4323A950BDA3-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME7B352464F
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME7C2631005
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME72330D70C
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME584C4C52U
Crash sensor for front airbag: driver side:
Serial number: 63732SME7050004CR
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME64505166X
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130702001425
Coding: 000016
VCID: 4FFB70D8D7D442339B9-801A
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 984 J HW: 8T0 920 984 J
Component: KOMBIINSTR. H35 0563
Revision: 00300000 Serial number: WVG47HK6E
Coding: 33AD010002012600010000
VCID: 46D555FC38AE837B28F-8012
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0056
Revision: 1Y070028 Serial number: 2841Y13613811A
Coding: 80CF07FF00
VCID: 4ACD61CC2CB6671BCC7-801E
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 8955830803
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 13176002211011200410
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011002225001120102
VCID: 56F585BCE80E33FB58F-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0028625771
Coding: 000000010001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311F345EB201EB86B-8060
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0310607949
Coding: 011B068280B900C08030003680000047
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813016632703
VCID: 2D070A50BD185023C95-8078
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
Coding: 011002225C01120102
Shop #: WSC 02391 785 00200
VCID: 55F782B0F50838E3515-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 10000000235244
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F2E0079D0FC8355D-806C
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109FD0D7688589
Coding: 010103010000000001
VCID: 2615F57C98EE637B08F-8072
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 666 F HW: 8R2 035 666 C
Component: H-BN-EU H46 0739
Revision: -------- Serial number: 206FX0D7531608
Coding: 130101020006C1ED05808F5E00000403E40000020000000000
VCID: 3C2137147662C9AB4EB-8068
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130FU0D2767162
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000001549349
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
End----(Elapsed Time: 01:33, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
On 1st browse, you have a supply issue on terminal 30, whether this is also in relation to the defective error is another question, check fuses & relays for tightness in the sockets & for any build up on the contacts.
Reactions: Sibmets
Hello again
Just to update this thread I have found the issue that was causing my lights to go wrong it was a loose fuse contact in the black holder on the drivers side.All my lights are working correctly now but I cannot seem to erase the fault code in the J519 module seen below.
One thing I have noticed is the fault counter for this is no longer going up since repairing the fuse holder but I have tried several times now to erase the code to no success.
Should I be concerned about it or not?
Regards Paul
Monday,23,November,2020,16:30:01:38628
www.Ross-Tech.com
Mileage: 68920km-42824mi Repair Order: After fuse contact repair
Revision: --H13---
Readiness: 1010 0001
Coding: 30154401
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 218
Mileage: 68927 km
Time Indication: 0
Date: 2020.11.23
Time: 16:11:17
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0722
Hex Value: 0x0010
Hex Value: 0x1098
Hex Value: 0x0000
Revision: 00002001
Coding: 642602C000
Coding: 00FD11
Coding: 02005D
1 Fault Found:
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00111110
Fault Priority: 1
Fault Frequency: 12
Reset counter: 255
Mileage: 68926 km
Time Indication: 0
Date: 2020.11.22
Time: 16:28:24
Coding: 000016
Coding: 80CF07FF00
End----------(Elapsed Time: 01:29, VBatt start/end: 12.2V/12.1V)-----------
