Hole in AC pipe
Will1893
Gloucestershire, UK
I've just found a hole in the ac pipe on my A3 3.2 quattro 8P, more of a gouge out of the pipe really. Its about an inch long located just above the connection to the g65 sensor.
Can I just get a second hand pipe and install with no problems? Or is there anything just need to know beforehand?
Thanks in advance.
All the refrigeration gas is now expelled, so a case of replace pipe and get it regassed
You might want to try figure out how the hole got there
Reactions: NHN and abmat
Your need to match the pipe as it maybe shaped different depending on the engine version, box etc, part numbers are your requirement here tbh.
A good used pip will be ok but make sure you buy new seals/O rings, green ones for A/C.
