Audi S3 2009 Fault codes
luckyluk3
Sweden
I've been having problems with the locks & alarm going off randomly, switched out lock actuators on both sides. Now the lock is working and the alarm isn't going off as often.
Today i did a VCDS scan and got some fault codes. Can someone shed some lights on these codes? Is there some code that can mess with the alarm?
I tried to scan the Central locking-module but couldn't. No contact or something.
I'll post the codes below or something, got flagged for spam.
Thanks in advance.
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52330817300560
Coding: 000003
Shop #: WSC 06314 000 00000
VCID: 4189F003D889C347D9-8014
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Temperature: 0.0°C
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K086090BFE
Coding: E9A31F061002021100
Shop #: WSC 40470 222 91322
VCID: 356194D35C417FE775-8060
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 136
Mileage: 173653 km
Time Indication: 0
Date: 2020.08.28
Time: 14:07:54
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 177073 km
Time Indication: 0
Date: 2020.10.21
Time: 16:27:53
Freeze Frame:
RPM: 830 /min
Load: 16.5 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 33.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
Comfort can error is common on facelift cars, ignore it tbh as never affected clients cars as nobody wanted to spend the time or cost finding the issue.
Evap, Google this, as common.
Change PDC module to resolve.
I see many different solutions for the EVAP, just switching out the N80 valve seems to do the trick only for like a week. I have no problems with the car at all though and the code just pops up once in a while, still worth getting this fixed?
Thanks alot for the answers.
508
776
690
MPP
