Retrofit alarm OEM a4 b9
sloth711
BE
Hello
I need help to retrofit OEM alarm on a4 b9...
My problem it's with connecting wires.
Someone have this?
Can explain?
Thank you
Enviado do meu STF-L09 através do Tapatalk
I'm assuming in your country alarm isn't fitted from factory.
What's the issue with your wiring?
Hi...
No its not from factory...
My problem is I don't have any wire on roof console... And for Sirène no wires to...
So I need know where I connect my cables?
I know it's on Confort module on back..
If I'm not wrong..
3 wires from roof console to sensor module...
And 3 wires to siren...
Correct?
Login to erwin online, you can pay for a days usage & that will advise you where to connect, it's not too expensive tbh.
Make sure your module fitted supports alarm 1st by checking visually the pin locations are actually there as it may code in but not have pins to connect too.
My confort module?
My last message stands mate, check module & wiring then go from there.
To connect my car or module to this website/program I need what cable?
Thank. You
You need to check the schematics 1st via the Erwin website to see which wiring locations are required & check your module is capable, then worry about the wiring.
You'll probably have to make the looms unless a company has the retrofit available already to fit.
I don't check erwin. I will check later..
Someone send me this
That's from elsawin, Erwin, if it's for B9 then should be ok, but again you need to confirm your module supports the function given your country spec didn't include this.
hi .. i see the wiring on paper
where i can check my module?
its that?
