Wear problem with NEW Brakes
Asahi
West Sussex
Hi all,
Yesterday I put new front discs and Pads on my car, my old ones judders and were below min thickness. After bedding them in this morning I noticed uneven wear. I then checked the old pads and it's the same story. Any idea? it doesn't look good to me. The passenger side isn't wearing the whole disc, is this normal ? When I did the brake job I cleaned all the calipers and pins good and used plenty of proper silicone grease for the slide pins. Not long ago I also flushed the brake fluid and bled. :persevere:
Link to imgur album
The pad never touches right to the edge of the disc either on the outer edge or the inner, perfectly normal.
Reactions: Asahi
That's very true but to me the difference in contact/wear seems alarming? Why would the drivers side pad make more contact that the passenger? I could only think cause its closer to the master cylinder but applied pressure should really be equal.
Incase it helps here's some pictures of the old brake pads.
I got Driver and Pas mixed up when so I'm not sure if they are paired correctly but I tried to match them.
The circle mark is from my diy piston windback tool and i used the pad to protect the piston.
