...Cracked my windscreen trying to push the cable between the A pillar and glass. Took hardly any pressure pushing the cable. Gutted
Sent from my iPhone using Tapatalk Pro
Having fitted a few now using the plastic tool and running the cable along the top of windscreen and down the pillar thankfully touch wood never had this issue.
Hopefully you’ll get the new screen sorted without any issues just remember if you have cameras etc fitted in the windscreen make sure you tell them![]()
WOW
I had to really push my cable into the Audi as the room was a bit tight, but never had this happen.
In my old golf, there was lots of room, but not in the Audi, the spaces are very tight.
At least you have a brand new Windscreen coming Ha Ha
That sucks dude.I was using a braided usb cable so think it had some friction to overcome. It’s only a 2.5 year old car so it wasn’t massively in need of new glass
Windscreens are reinforced on the outside I believe so it’s actually pretty easy to crack one when working from the inside, especially if the glass is cold. This is why I remove trim as opposed to try and “tuck” cables under.
Pretty easy to be honest, but then so have been doing 2 to 3 of these a week for as long as I can rememberI have learnt a costly lesson thenhow easy is it to remove the A pillar trim inside?
How could you crack it?? u been using metal screwdriver right? aaah well always use plastic prying tools.....Cracked my windscreen trying to push the cable between the A pillar and glass. Took hardly any pressure pushing the cable. Gutted
Call insurance it happened while u been driving u should have coverage... sort off
really didn’t take much to crack it from inside considering the boulders that some lorry chuck up at the car from the outside at motorway speeds I’ve had in the past.That's the problem with Audi, the trim parts fit too wellOther makes you can pull the trim back and get your hand in!
