VCDS Measuring Blocks Unavailable?
DeadLock
Surrey
Hi Guys and Gals,
Running VCDS 18.9.0 and need to check torsion value. But when I go into Engine, the Measuring Blocks button is greyed out. I've also tried going into Advanced Measuring Values but there is no Torsion Value item to select.
A3 8P CFFB 2.0TDi with no DPF and a lot of smoke when cold! Also a little bit lumpy when idling. Smoke can be bluish grey so hoping to check torsion value as I believe if this is off it might cause some of the blue at least in the smoke.
Any ideas?
