Facelift Stock Resonator - 8V S3
K1NGY14
Hi all,
Quick question.
Are the Golf R and S3 exhaust systems exactly the same? I’m after a resonator and the only ones I can find are off a Golf R.
No difference in FL and PFL exhaust system up to 2019......2020 has an emission change but should not affect fitting a resonator that has been cut and removed and a resonator removal pipe fitted on all 2015 -2020 S3.
The only issue may be the overall length of a cut out resonator, if you are trying to fit a resonator to an S3 that has a resonator delete pipe.
Reactions: HertS3 and pburv
As mentioned above it will fit FL. But yes depends on length of resonator cut out. Are you able to measure your res delete pipe?
39
13K
199
41K
13
