2013 A4 B8.5 creaky or squeaky front suspension.
Hafizkam
Stoke on Trent
I have a 2013 a4 2.0 tdi b8.5 avant
Front drivers side suspension is creaky over bumpy roads and speed ramps etc.
When car is uneven as turning left or right etc it also creaks too.
Had it checked from 3 Mechanics. All 3 have said all suspension arms and bushes etc look perfect
Had drivers shocker changed as one said it was weak.
Still have the same issue.
Any help please
I got odd creaking after getting a stone chip from a resurfaced road caught some where. G took it to two independents and Audi, Eventually it naturally went.
Sent from my SM-N960F using Tapatalk
Sounds too bad for a Stone chip or some chippings to get stuck.
Its quite loud.
On the straightt car is 90% fine.
Just creaks when road is bumpy or on a speed hump as you come back down
Had it for about 2 weeks now.
Done about 750 miles. Still the same
I had this once. I loosened the clamps around the antiroll bar bushes and sprayed chain lube grease in them. Sorted
Reactions: CHEZ and ruairi83
@ChrisF88
Have you had any parts changed at all?
Booboo i might try what you have said.
Its a very annoying creak especially when mechanics say all is perfect and even would pass a M.O.T
@ChrisF88
Not changed anything yet. Hoping to get a look at the ARB links soon but would have expected the garage to spot any issues with these when they inspected it.
@ChrisF88
Ive just had the driver side front drop link removed as mechanic suspected that.
Drove car for a mile or 2 without it...same noise still there...so had the drop link put back in.
Is the ARB and Droplinks same thing or 2 different things?
I'll give an answer, the drop links connect the ARB to each of the front suspension "verticals", so to isolate the ARB mounting bushes from causing this noise, both drop links would need to be removed and that would stop the ARB rotating in its mounting bushes while the car's front suspension vertical parts compress/extend. So your ARB mounting bushes are still able to cause noises when only one drop link is removed.
Reactions: Booboo
Any help please
I currently have the same problem been listening to a creaking noise for a few months now first started after jacking up the one side of the car to change a flat on passenger side I’ve had it up on a four poster ramp and it’s a bit dirty under there when the belly tray is taken off you can clearly see the arb bushes but wouldn’t of thought they would creak like that I thought top mounts or a worn bush but couldn’t see anything out of the ordinary no splits I’m going to try some lithium grease or copper grease out of a spray can and see if it stop creaking mines a 2011 2.0 b8 avant estate creaks like a ship going over bumps or up a kerb annoying as hell
Mines seemed to start after being in to have the wheels rebalanced. No idea if it was jacked one corner at a time or not though as I wasn't there.
I wondered if something just hasn't reseated correctly after having all weight off the suspension.
Hi.
Car went in yesterday
Had the Arb links changed at £103 each.
Both sides
Creaking noise still there.
Top mounts are perfect so no issues there.
Took it to a indy audi specialist today.
Gave car a good under body wash today.
Jacked car up passenger side.
All fine he said.
Jacked car up driver side.
All fine he said.
He greased all the rubber bushes etc that he could see..then tried pushing them about to see if any cracks but nothing major. He said all is perfect and nothing needs to be changed.
Since then noise has gone.
Very weird.
Done about 15 20 miles of local driving on bumpy roads and ramps etc.
Noise has gone.
Hi.
Both sides
All fine he said.
All fine he said.
Very weird.
Noise has gone.
Thanks for keeping us updated.
Hopefully the creak stays away. Looks like I'll be getting the trolley Jack, axle stands and a tub of grease out at the weekend.
What grease is recommended for this?
Just for anyone looking at this at a later date.
I ended up needing an O/S front lower suspension arm replaced and since then the creaking has stopped.
Reactions: maxlangley
h
Hi.
Both sides
All fine he said.
All fine he said.
Very weird.
Noise has gone.
Has this permanently fixed the issue?
h
Yes this will have i changed all the front arms in one go, you can change just the lowers but thats only 1/6 of the job, buy a MEYLE full control arm kit and get it fitted transforms the ride, no tramlining sqeaks or rattles perfect tracking at 90k miles feels like new.
h
That forum member was last on this forum January 2022, so I wouldn't hold out for any response from them.
It did sound like them slackened off the 2 ARB mounting clamps and greased the "rubber" mounts inside these clamps, I'd only ever use red rubber grease or another grease that would not react with the rubber mounts/sleeves.
Edit:- possibly these clamps have bolts on them that can only be used once, that is just a suggestion, so maybe buy a set of ARB clamp bolts before starting this job.
Reactions: spartacus 68
This is something I am finding with My 2012, its done over 160K and I suspect they haven't ever been changed. I did have a broken spring on my old 2005 A6 which also caused a creak from the rear.
