Rust spots on roof (pic attached)
kpm278
Hampshire
Hi
I’ve got the odd stone chip around my car (2014) where I can see the metal (or primer, not sure) and they never rust, but I just noticed four chips on my roof and they’re all rusty brown. That normal?
Just an opinion ..............
Looks to me like a "Rock" has hit the roof and "Knocked" off the paint !!!
It's going to require going to a body-shop and to do it right.
Completely repaint the roof.
And just guessing if it goes back to an Audi Dealership for them to do the repair right.
It's probably going to be expensive.
Terry
The damage in the picture looks like as said above, something has bounced off the roof.
If they are going to do so paint chips take a while to rust, which should give one plenty of time to notice them and dab with touch up paint to prevent this from happening.
That one does look quite large though.
If it were me I would try a spot repair. Quite time consuming, and needs careful work. Carefully de rust the chip with a pick and something like Jenolite, then a tiny dab of primer, applied with the tip of an artist’s paint brush, followed by a wipe of spot filler, then top coat built up in layers until just above the level of the original paint. When fully cured, light spot sand with very fine wet and dry, then finish with single coat of clear lacquer and polish when cured. Key is to keep the repair localised on the chip, and not let it spread into a large patch. Helps to stick some masking tape with a suitably sized hole over the chipped area.
Or if this is all too much, or you don’t have the materials and somewhere dry to work, call up one of the Chips Away” type companies!
