Parking Sensors FF 8P1 Sport to 8P2 Hatchback. Possible?
Fluffy
Bristol
Hi. I have a 54 Sportback 2.0 TDI with factory fitted rear parking sensors. Sadly it was written off by the bf last month. So now I have a lovely 1.4 TFSI S-Line Hatchback and wondered if I can fit the parking sensors from the TDI straight across or if there would be any snags. Thanks
Hey Fluffy, welcome to the forum!
As far as I know you can fit parking sensors as a retrofit to most cars so in theory you should be able to put those sensors into your new car. My guessing is it would be a case of installing them and then coding it in via VCDS although I may be wrong so I may be corrected!
Enjoy your new car and the forums, lots of great people on here with tons of knowledge
Eren
54 plate has the 22mm versions, you can move most things over but it will require some work.
Whereabouts are you located?
