Help with mmi screen
vw754
vorsprung Durch Technik
U.K
Battery went dead, jump started it..... Now no mmi screen coming on, no stereo working
Thursday,09,January,2020,17:41:20:07086 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64 VCDS Version: 19.6.2.0 (x64) Data version: 20190930 DS308.0 www.Ross-Tech.com VIN: WAUZZZ8X4CB034354 License Plate: GEMMA A1 Mileage: 142530km-88564mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8X-AU21 (8U0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F VIN: WAUZZZ8X4CB034354 Mileage: 142530km-88564miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 5F-Information Electr. -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb Part No SW: 03C 906 016 BG HW: 03C 906 016 BG Component: 1.4l R4/4V TS H08 9080 Revision: LEH08--- Serial number: Coding: 00190012000401000000 Shop #: WSC 01286 386 08256 ASAM Dataset: EV_ECM14TFS01103C906016BG 001007 ROD: EV_ECM14TFS01103C906016BG.rod VCID: 65CBA2DA647A686734-8030 2 Faults Found: 5273 - Output for Starter Relay P0616 00 [036] - Short to Ground Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 142533 km Date: 2020.01.03 Time: 03:01:29 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 94 °C Intake air temperature: 48 °C Ambient air pressure: 980 mbar Voltage terminal 30: 11.779 V Unlearning counter according OBD: 40 Starter control: terminal 50-Bits 0-7: 00000000 Status of starter activation-Bits 0-7: 00000000 Coolant temperature at engine start: 94.5 °C Starter control: terminal 50 acknowledgment-Bits 0-7: 00000000 System status for the start/stop function master: 1 System malfunctions for active participants start/stop-Bits 0-7: 00000000 System malfunctions for active participants start/stop-Bits 0-7: 00000000 Error status for start-stop related sensors-Bits 0-7: 00000010 5459 - Control Circuit for Starter Relay 2 P3048 00 [036] - Short to Ground Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 142533 km Date: 2020.01.03 Time: 03:01:29 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 94 °C Intake air temperature: 48 °C Ambient air pressure: 980 mbar Voltage terminal 30: 11.779 V Unlearning counter according OBD: 40 Starter control: terminal 50-Bits 0-7: 00000000 Status of starter activation-Bits 0-7: 00000000 Coolant temperature at engine start: 94.5 °C Starter control: terminal 50 acknowledgment-Bits 0-7: 00000000 System status for the start/stop function master: 1 System malfunctions for active participants start/stop-Bits 0-7: 00000000 System malfunctions for active participants start/stop-Bits 0-7: 00000000 Error status for start-stop related sensors-Bits 0-7: 00000010 Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH Component: ESP8.2i front H07 0001 Revision: -------- Coding: 330448E9237000B6CC2812E7C4D500910C00 Shop #: WSC 00046 000 00000 VCID: 7F0710B2EAE6D2B7DE-802A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 8X0 820 045 A HW: 8X0 820 045 A Component: J255 Klima Manuell 0140 Revision: 0000707S Serial number: 03030005744434 Shop #: WSC 00046 000 00000 VCID: 346D0F9E5720C1EF73-8060 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb Part No SW: 8X0 907 063 G HW: 8X0 907 063 G Component: BCM PQ35 M 110 0655 Revision: 00110 AE Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4922DC0887830045 Shop #: WSC 00046 000 00000 VCID: 4085534ED3986D4FE7-8014 Subsystem 1 - Part No: 8X0 951 177 Component: DWA-Sensor H0 H01 0020 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8X0-959-655.clb Part No SW: 8X0 959 655 A HW: 8X0 959 655 A Component: Airbag10.41 H04 0008 Revision: -------- Serial number: 003JJ0033B3I Coding: 30314539303330303034554A305238583053 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_Airba1041BPAAU210 001015 ROD: EV_Airba1041BPAAU210.rod VCID: 48954B6EF3A8550F2F-801C Crash sensor for side airbag: driver side: Serial number: 3554VRB405N0JL5GG0Q6 Crash sensor for side airbag: front passenger side: Serial number: 3575HRB405V0NLV258LB Crash sensor for front airbag: driver side: Serial number: 3585HRB40550N3MKG92D Rear Impact Crash Sensor: Serial number: 3515ZRB404V0L9U47H43 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb Part No SW: 8X0 953 501 B HW: 5K0 953 569 H Component: LENKS.MODUL 014 0140 Revision: FF010016 Serial number: 20110813300558 Coding: 1184004000 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 39733EAAB8423C87A0-806C Multifunction steering wheel control module: Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C Component: E221 - MFL H08 0009 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1 Part No SW: 8X0 920 980 C HW: 8X0 920 980 C Component: KOMBI_MEDIUM H03 0179 Serial number: 00000000000000 Coding: 41DE00 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390 ROD: EV_Kombi_UDS_VDD_AU10.rod VCID: 3F8750B2A66612B79E-806A No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb Part No SW: 8U0 907 468 A HW: 8U0 907 468 A Component: GAT 4CAN 1L M H10 0044 Revision: 1P040023 Serial number: 2341P118308208 Coding: FBCF0064000100010153 Shop #: WSC 00046 000 00000 VCID: 4085534ED3986D4FE7-8014 Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H Component: J367-BDM H07 0171 Serial number: 00000000007100358390 Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663 Component: J532_DCDCStab H17 0042 Serial number: 11257000458011200181 1 Fault Found: 00384 - Optical Databus 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 228 Mileage: 142533 km Time Indication: 0 Date: 2020.01.03 Time: 02:59:13 Freeze Frame: Bin. Bits: 10111 Voltage: 11.80 V Count: 6 Bin. Bits: 00000 ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 8X0 920 980 C HW: 8X0 920 980 C Component: IMMO H03 0179 Serial number: Coding: 000002 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110 ROD: EV_Immo_UDS_VDD_AU10.rod VCID: 3F8750B2A66612B79E-806A No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb Part No SW: 8X0 959 793 D HW: 8X0 959 793 D Component: TSG FA H09 0409 Revision: -------- Serial number: -------------- Coding: 011E02200101000100 Shop #: WSC 00046 000 00000 VCID: 4E997D7619CC8B3F65-801A 1 Fault Found: 02123 - Door Warning Light / Entry Light 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 228 Mileage: 142533 km Time Indication: 0 Date: 2020.01.03 Time: 02:59:24 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11251 Shop #: WSC 00046 VCID: 2F6700F2EA06E2370E-807A No fault code found.
Have you clicked on clear the fault codes shat down and restarted the vehicle and tried the radio again ?
