Hi guys
thanks in advanced.
so around me we have got some high water and roads are flooded and my power steering has started to play up so i got the car in the workshop and pulled all the plugs on the bottom or the rack and air lined them out and sprayed some water displacemnt water was present but not on the contacts.
vehcile is
audi a5 2012 3.0 tdi quattro
ill attach the saved DTCS from VCDS
after clearing codes i have the following left
steering assist:
C10AD position sensor for motor signal implausible
steering wheel:
00778 steering angle sensor (g85)
014 - defective
any help as to what i can do next? is it a rack replacement or not
thank you and merry christmas
heres the codes i cant clear
CODE 1
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20111109001207
Coding: 000036
Shop #: WSC 06325 000 00000
VCID: 4FAD53361E3D25376E-801B
Component: E221 - MFL H03 0003
1 Fault Found:
00778 - Steering Angle Sensor (G85)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 89207 km
Time Indication: 0
Date: 2015.10.03
Time: 12:34:45
Freeze Frame:
Voltage: 14.60 V
Hex Value: 0x32A0
Speed: 9.0 km/h
Steering Angle: -221.46∞
CODE2
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 982 F HW: 8T0 920 982 F
Component: KOMBIINSTR. H23 0639
Revision: 00000000 Serial number: JS531HWAC
Coding: 3327010003012600010000
VCID: 408F600AD363CA4FE7-8015
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 73
Mileage: 176184 km
Time Indication: 0
Date: 2019.12.26
Time: 13:24:41
CODE3
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0009191216
Coding: 100000000001
Shop #: WSC 61962 000 1048576
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 34673CDA9FDB66EF73-8061
2 Faults Found:
7341570 - Position Sensor for Motor
C10AD 29 [137] - Signal Implausible
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 176057 km
Date: 2019.12.23
Time: 17:30:11
Write only channel
7341632 - Position Sensor for Motor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 176057 km
Date: 2019.12.23
Time: 17:30:14
Write only channel
CODE 4
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 670 A HW: 8R2 035 670
Component: H-BNT-EU H42 0467
Revision: -------- Serial number: 068JS0B7501013
Coding: 130101020006A1EF41A08F5E00000403040000000100000000
VCID: 326B3AC26DCF68DF61-8067
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130JG0BS048972
Subsystem 3 - Part No SW: 8T0 919 611 C HW: 8T0 919 611 C
Component: E0380 Bedient H02 0020
Serial number: 00000000978452
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 73
Mileage: 176184 km
Time Indication: 0
Date: 2019.12.26
Time: 13:24:52
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000001
thanks in advanced.
vehcile is
steering assist:
steering wheel:
014 - defective
CODE 1
Coding: 000036
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 89207 km
Time Indication: 0
Date: 2015.10.03
Time: 12:34:45
Freeze Frame:
Voltage: 14.60 V
Hex Value: 0x32A0
Speed: 9.0 km/h
CODE2
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 73
Mileage: 176184 km
Time Indication: 0
Date: 2019.12.26
Time: 13:24:41
CODE3
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 176057 km
Date: 2019.12.23
Time: 17:30:11
Write only channel
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Mileage: 176057 km
Date: 2019.12.23
Time: 17:30:14
Write only channel
CODE 4
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 73
Mileage: 176184 km
Time Indication: 0
Date: 2019.12.26
Time: 13:24:52
Freeze Frame:
