Strange random oil consumption change oil normally runs out every three months.
riccccccardo
Hi
I’m looking for answers?
Re my 2.0 tfsi bul Quattro Se.
I don’t understand this car at all for last 4 years oil light goes off every 3 months from full. Today the oil light went off December 2019. I last topped up May 2019. So the oils lasted 7 months even though I’ve done nothing different and driven the same distance of 8k a year.
What annoys me even more after speaking with castrol customer service I was going to change in 2020 from my current 5w30 to 5w40 as they said 5w40 should last longer in my car.
FYI I get the car serviced like clock work By Audi every year with no leaks, errors or issues etc, no expenses are spared on my car.
I have been using 5w40 for quite some time now and is far better in these engines than 5w30.
My old bus used to drink 5w30 like it was going out of fashion , but since running ester based 5w40 it is very good , even after some heavy right foot driving consumption is very acceptable, well for an audi tfsi that is.
To be honest I check it weekly without fail and I've never had an oil light alert to date, I don't think i'd ever wait for a low oil light, prevention is way better than the cure with these engines.:icon thumright:
Reactions: riccccccardo
Thanks for that let’s me know I’m doing right thing changing then.
I’d owned my golf gti 1.8 8 years and never had to top up between services like this f******* car lol if I cud get this audi down to 1 or 2 top ups between services I’d be very happy lol
Hi, Robs advice on oil is sound as usual, but can I ask the mileage of your engine ?
i found this the other day I think I’m going to be writing another stinky email to Audi Uk soon. Even considering to pay for this ****** Consumption test :( It’s not fair the Americans got this issue fixed for free via a class action. Why do Uk/Europe always get the raw deal? Why don’t we also have a class action Etc to get Audi to do what’s right?
http://casestudies.atlanticmotorcar.com/audi-engine-oil-consumption-correction/img_8120/
The early version of the TFSI gasoline engines found in the A5, A4 and Q5 have an inherent design fault which leads to high consumption of oil.
The base problem seems to relate to the piston rings, which allow small amounts of oil to leak round the pistons into the cylinders, where it burns and therefore leads to high oil consumption. The typical way drivers become aware of this is when the ‘add one litre of oil’ notice comes up on the dashboard. When this comes up you don’t need to immediately stop, but you should add a litre of correct grade oil as promptly as you can.
Over time this problem gets worse, and the range you can drive before needing to add oil steadily drops. In advanced cases there can be noticeable smoke from the exhaust under heavy acceleration, and it is also known to damage the actual cylinders themselves, causing scoring in the bores. One theory is that these grooves cause more and more oil to leak around the pistons, hence the problem gets progressively worse.
Note that the Audi specification for the 2.0 engines allows for a quart of oil to be used every 1,000 miles, and they will not consider this level of usage to be a fault. This is written in the manual if you look in the section on oil. However, many 2.0 TFSI owners routinely get only around 500-600 miles, which is definitely out of spec. (Other engines may have different specifications, please check your manual to confirm)
What engines are affected?
The 2.0 and 1.8 TFSI engines prior to 2012. Engine codes known to be affected include CAEB, CDNC and CNDC (list being updated). The problem seems to have been corrected when the facelift was released. But all A5 TFSI engines before that, i.e. 2008 – 2012, are susceptible.
The overwhelming majority of reports are for the 2.0, but 1.8 TFSI is also affected. There have been far fewer reports from 1.8 owners and information is harder to find. It is unclear whether this is because the 1.8 is less susceptible to the problem, or there are simply less 1.8 engines in existence.
Diesels engines are not affected, but there have been isolated reports of the larger petrol engines such as those found in the S5 also having an oil problem, but it’s unclear if this is the same issue. Again, S5’s are far less common than 2.0 TFSI A5s, so that may be the reason there are few reports of this.
The following advice should be generally applicable for any owner with oil problems, but is primarily based on the experience of 2.0 owners. If you have a different engine and find information that contradicts this FAQ, please post below and I will update.
How can I tell if I have the problem?
It’s fairly easy to test. Top up your oil then reset your odometer. When the one litre message comes up if you’ve done less than 1200 miles you have the problem. In practise if you are getting anything under 2000 miles you probably have the problem, but Audi won’t acknowledge it until you get below 1200 miles. (this is correct for 2.0 engines, I am not sure the spec mileage for other engines)
However, for Audi to do any corrective work you need to have an official consumption test done by a main dealer. For this they will drain your car of oil, then fill it up with a carefully measured volume so they know exactly how much is in the engine. You are then asked to drive 500 miles, or until the one litre warning comes on, whichever is first. At that point you return to the dealer, they drain the engine again and carefully measure how much is left. In this way they can get an extremely accurate measurement of the oil used over the distance. If more than half a quart has been used over 500 miles, the car has failed the test and they will recommend a repair. It is essential that you not top up the oil during the consumption test, as it will invalidate the result.
Audi dealers will typically charge $80-125 for the consumption test, although this is sometimes waived for goodwill.
Can I ignore it?
For a long time, especially when Audi wasn’t offering much in the way of financial contribution, many TFSI owners took the view that it wasn’t harming the engine, and buying a 4 quart bottle of oil every few months was a lot cheaper than the repair.
However, it has now been confirmed that the problem does harm the engine, it causes scoring and grooves to be worn into the cylinder bores. In the short term these make the problem worse, longer term this could eventually cause the engine to fail.
So you are strongly advised not to just ignore the issue.
Can it be fixed?
There are three known solutions offered by Audi.
Stage 1
This involves replacing the crank case and updating the engine management software to the latest release. While it appears to reduce the problem in some cases, and is sometimes offered alongside the consumption test as an initial fix, it does not seem to be a permanent solution and Audi does not seem to be offering it very often anymore. Audi dealers typically charge $200 for this but it is sometimes offered free with the test as goodwill.
Stage 2
This involves removing the engine from the car, stripping it down to the cylinders and replacing the pistons, piston rings and con rods. It takes around 12 hours to do this, so it is not a trivial piece of work. Provided there is no other damage the stage 2 solution will completely fix the problem. Audi dealers typically charge $5,000 – $6,00 for this.
However, before conducting a stage 2 fix, the dealer should check the cylinders to see if they have been damaged. This is done either by stripping the engine, or by putting an endoscope in through the spark plug sockets. If the bores are damaged the stage 2 fix is not suitable as the grooves will still cause oil to leak around the rings.
Stage 3
The final repair option is a completely new or good quality used engine, and this is the only fix that will work if the cylinders have been damaged. This is a permanent fix, the replacement engine will not have the same problem. Audi dealers typically charge $12,000 – $14,000 for a new engine this.
Note that both the Stage 2 and 3 are permanent solutions, neither is more effective than the other, and there is no requirement to have the stage 2 before you have the stage 3, in fact that would only happen if the dealer missed there being engine damage in the cylinders.
The only thing that decides whether you need the stage 2 or 3 is the presence of scoring damage in the cylinders.
Other solutions.
Some drivers have reported that using different grades of oil, or engine treatments such as STP, can improve the problem. But while there might be some small incremental improvement, there is no evidence that they significantly reduce the problem or provide a fix. Crucially, Audi doesn’t seem to have ever recommended these solutions, and given how expensive the other options are it seems likely they would have at least tried it if there was any chance it might work.
What are Audi doing about this?
For a long time Audi dealers were quite reluctant to admit there was any problem, and while they did provide the various fixes listed above, unless the car was still in warranty the owners were typically requested to make a significant contribution to the cost, sometimes to the tune of several thousand pounds. After market warranties also didn’t seem to cover the issue as it was either categorised as a manufacturer defect or else wear and tear. This left many owners facing having to live with the problem due to the huge expense of rectifying it.
However, in 2014 a class action lawsuit was brought against Audi in America, and while they have not formally admitted liability, they have made a settlement offer to American owners. This extends the manufacturers engine warranty to 8 years or 80,000 miles, and will fully cover the cost of the required repairs up to and including a new engine. American TFSI owners should read this website to find out details of this and how they can claim.
Apparently as a result of this finding in America, as of 2015 Audi in other countries appears to have had a change of heart and are now making 100% contributions to remedial work for affected cars that meet their criteria. In March 2015 I personally had the stage 3 fix, i.e. a whole new engine, provided completely free of charge despite my car being two years outside of its manufacturer’s warranty.
In June 2015 Audi UK made the following statement in response to an article on BBC Watchdog about the problem. It essentially confirms that they are contributing, but that certain service criteria need to be met. (original statement here https://www.audi.co.uk/about-audi/la…june-2015.html )
Quote:
Audi UK is committed to investigating and swiftly resolving any technical issues relating to our cars which are reported to us through our network.
As we have stated previously, a low percentage of older 2.0 TFSI engines fitted to certain models have been exceeding the factory oil consumption tolerance of 0.5 litres per 1,000 kilometres (approx. 620 miles). Changes were made to the production tolerances of the pistons and rings in this engine from mid-2011 onwards, and customers with 2.0 TFSI cars produced after this date should not have any cause for concern.
The comprehensive Audi UK Warranty (3 years/60,000 miles) covering all new Audi vehicles has already resolved the majority of these cases at no cost to the customer. For remaining affected customers with cars that are no longer covered by this warranty, we have a policy in place to resolve issues on a case-by-case basis. This revised policy has been in force nationally since the beginning of the year and applies to new and retrospective cases. Qualification criteria are applied in each individual case to confirm that the vehicle has been serviced in accordance with the owner’s handbook by an Audi Centre or other professional workshop which follows the Audi Service quality standards.
We invite all Audi customers who have any questions or concerns relating to newly discovered or previously reported oil consumption with 2.0 TFSI engines to contact their local Audi Centre. Alternatively, our advisors will be available until 10pm on Thursday 4 June, and thereafter from 8am to 8pm, by calling 0800 093 0110 free of charge from landlines*.
*Chargeable from mobile phones.
What are the criteria for getting the fix for free?
There appear to be two main criteria.
1. You have a full Audi Service History
2. You engine has not been in any way modified, e.g. a performance remap or any other after market modification
If you have a less than perfect service history, Audi may reduce their contribution and you will need to make up the difference. However, there is some evidence that if you can produce garage receipts showing that the correct grade of oil was used, this may mitigate against this. The relevant line in the Audi press statement is “the vehicle has been serviced in accordance with the owner’s handbook by an AudiCentre or other professional workshop which follows the Audi Service quality standards.”, so if you have used an independent garage you may need to provide evidence that they followed Audi standards.
An engine remap or similar after market modification will likely cause Audi to refuse all contribution and it will be difficult to argue against this. It’s likely to be hard work though and there are obviously no guarantees.
Another unofficial factor appears to be the particular dealer you go to. It seems that Audi expect the dealers to contribute to the cost as well, and some dealers seem more willing to undertake the work than others. Your personal history with the dealer may also help here, if you have had several services and other work done by the main dealer, they are more likely to help. But if you turn up with a problem car and it’s the first time you’ve ever spoken to them, you may have a harder time.
I have an affected car and I’m pretty sure it’s out of spec, what should I do?
If you are in the US, read the class action page linked here.
Oil Consumption Settlement > mainpage > Home
In other countries, take it to your local dealer and say you have an oil consumption problem and would like them to look at it. BE POLITE, it is the dealer who will apply to Audi on your behalf for the contribution, so you want them on your side. If you go in demanding your rights, quoting law suits and generally being a pain, like any other human they are less likely to go the extra mile working on your behalf with Audi. You can always bang the table later on if the contribution isn’t what you want. I asked very politely and their opening offer to me was a completely free replacement engine without any negotiation required at all.
If the dealer doesn’t cooperate, either consider another dealer or else speak to Audi direct. You may want to ask in this thread for a recommendation of a helpful dealer or who to speak to at Audi. However, the issue is getting more and more profile and publicity, having been featured in the UK national press, and more recently on the BBC Watchdog consumer affairs program. This should lead to more and more dealers following the Audi line and fixing the problem.
I already had my car fixed a year or so ago, and paid a hefty contribution
Some owners who previously paid large contributions towards a fix are now understandably upset that work they paid for is now being provided free. When this issue was featured on Watchdog, four owners were shown who had previously made contributions, and as part of their response to the article Audi agreed to refund all four of them. So if you previously paid to have this problem fix, you should politely go and speak to the dealer who did the work, quoting other examples of owners who have had the same work fixed for free. It would appear there is a very good chance you will be issued a refund.
I am thinking of buying a pre-2012 Petrol TFSI car and heard about this issue, what should I do?
Many owners who realised they had this problem but didn’t know or believe that Audi would fix it have part exchanged their car to be rid of it, so there is likely to be quite a large number of affected cars in the used market. If you are considering buying any pre-2012 car with this engine for your own sake you should work on the assumption that it has the problem and it is likely to get worse. Bear in mind that even on badly affected cars you have to drive several hundred miles to be able to diagnose the issue, so dealers who have taken these cars in part exchange could well be completely oblivious to it and you can’t rely on any dealer assurances. Although a written assurance would be useful if you later want to make a claim.
However, that doesn’t necessarily mean you shouldn’t buy the car, and in fact you might be able to get quite a bargain as a result. But keep the following in mind.
1. Don’t touch any example that doesn’t have a full Audi Service History, or at least negotiate a very serious discount, e.g. $4k to cover the potential contribution
2. Don’t touch any car that you think might have been remapped or modified
3. Even if the car appears to be on the level , be aware that you might have to go through several months of hassle to get the problem resolved, and as with any used purchase there is always the risk that something will crop up (e.g. a remap or dodgy service) that leaves you needing to make a contribution. Use the normal rules of used purchase to minimise this risk, i.e. a dealer is safer, an Audi dealer safer still, and if its a private sale then buyer beware!.
If you are at all in doubt, or just don’t want the hassle, walk away from any car with this engine. Either go for a diesel, or wait a year or so until the Facelift models come down to your price point. Don’t risk getting stuck with a dying engine that Audi won’t touch and you can’t afford to fix.
Reactions: DirkOz
you need to check out the owners handbook really before you go steaming ahead.
Owners handbook clearly states the oil consumption can be upto 0.5ltr per 600klm under spirited driving for these engines.
Unless you are using more than this amount irrespective of time period it is classified as normal and a lot of cars are just as bad to be honest.
You should also be checking your oil level on a regular basis based on the audi's figures.
sorry to be so blunt but it the way it is with these, been there with audi so i know exactly the situation, and the BUL engines were not effected by the oil consumption issues that 2008 and beyond suffered with.
Hi your right Audi told me mines not one of those on the bad list :( and re that’s the way it is. I didn’t know or do my research before buying the car enough and the oil consumption for this car is ridiculous bearing in mind my first cars were 1.6 ford escort mk 4, 1.6 ford escort mk 7 and 1998 vw golf gti 1.8 turbo all petrol.
Sadly all engines vary in the amount of oil they use , and all engines will use oil . my previous 2006 Subaru legacy 3.0 spec "B" used very little , but a friend has a 2010 mini cooper and it drinks even more oil than a tfsi and its a well known issue with many mini's.
Just check it weekly and get on with life really, I do.
Hi your right Audi told me mines not one of those on the bad list :( and re that’s the way it is. I didn’t know or do my research before buying the car enough and the oil consumption for this car is ridiculous bearing in mind my first cars were ford escort mk 4, ford escort mk
which why my next cars will be Japanese preferably Toyota lol
