Hi guys, long time since I posted anything on here and unfortunately my first post in a long time is due to an issue...
Car is a Feb 2017 S3.
Earlier tonight start/stop showed on the dash as an error, revs got pretty lumpy and then car sounded like it was running on all cylinders. Yellow / orange exclamation mark at the top of dash and also yellow / orange car at bottom appeared (virtual cockpit)
Was stranded so a slow drive home for a couple of miles followed, car was definitely not right. Switched start/stop off and this seemed to cure the issue on the drive back. Back at home, started again and with start/stop on again engine returned to being lumpy.
A quick VCDS scan and the culprit seems to be the last of the 3 codes - 000802 - engine speed sensor (G28). The other two codes are 000665 and 004243, however VCDS notes these have only occurred once whereas 000802 has twice and this code also states MIL on.
Anyone had this issue before? Car is still just inside warranty so will be speaking to Audi but would be helpful to be armed with any prior info / experiences?
Phone won’t let me upload pictures of VCDS scan onto here...
