So I have tried to change my front parking lights into LED's, I took out halogen bulb in one of the lights and replaced it with an LED, but it didn't light up. Then I replaced it with a halogen again, but it wasn't lighting up either, so I decided to try and change the one in the other headlight, which was still working, lo and behold it also had the same problem and stopped working. I've had some time during the weekend and decided to test it for errors using VCDS and measure the voltage using multimeter.
Results were that the control unit is sending voltage into the parking light sockets at about 12v, but when I measured it with the meter it didn't record any substantial voltage it was like 0.56v. So, does anybody have any ideas? I checked the fuses, which seem to be ok, I also checked the wires themselves at the point of contacts and they also have not voltage, so it can't be contacts fault.
