TPMS retrofit
Depends on a few things, ok implementation, 2 systems, valve pressure sensors or abs module type.
Would need to check which system they utilised on the C7, then go from there bud.
Whereabouts are you located?
i've got abs module type already, but i'm forever having to check the pressures as it only seems to trigger if there is a big fluctuation
midlands
Assuming you've reset everytime.
Could check to see if the alternative system is available as that would be sensitive.
yeah i do always reset, but recently with the weather change nothing was detected and every tyre was 4-5psi down, only really good for detecting a puncture, which i haven't experienced yet (touch wood)
