TTE777 EVO Upgrade Performance Turbocharger TTRS 8S, RS3 8V.2
TTE Si
Site Sponsor
Site Sponsor
UK
TTE777 EVO Turbocharger for the DAZA & DNWA 2.5 TFSI EVO engine
A TTE777 Is an original RS3 8V.2/TTRS 8S turbocharger that we the THETURBOENGINEERS Rework to make a class-leading performance hybrid yet still plug & play fitting with an upgrade inlet. To make a TTE777 the compressor wheel is exchanged for a TTE milled aluminum wheel with state-of-the-art geometry, 7+7 blade so producing extra power, that's even bigger then TTE700 wheel. Equally, we change the original exhaust turbine for a far larger but very lightweight 9 blade TTE designed the turbine for lower exhaust gas backpressure giving greater performance. We also fitted a TTE motorsport upgrade bearing system for durability.
Boost response as always is focused on when we were designing this unit and it does not disappoint.
With the TTE777 stage we have CNC ported the exhaust manifold to match the OEM gasket at the head flange and smooth the transition in each exhaust runner to improve gas speed and flow, so improving efficiency to the much bigger 9 blade low mass turbine and so driving the larger compressor harder. We also made other power modifications with regards to the turbine side of the TTE777 unit to increase gas flow.
Features :
  • TTE Billet Highly efficient compressor geometry
  • TTE 9 Blade High-flow Low-mass turbine
  • TTE Upgrade bearing pack
  • Genuine BorgWarner Turbocharger as the base part
  • Genuine BorgWarner actuator
  • Thermally shielded exhaust manifold and housing
  • CNC Optimized Compressor Cover Machining Clearances
  • CNC ported manifold
  • Plug and Play Installation
  • 700+ depending on fuel (link here for required upgrade injectors)
  • Single parts finely balanced then components assembled and core high-speed VSR balanced
  • Supplied with a balance test result document
  • Proven TheTurboEngineers quality
  • Made in Germany
More info and price here : https://tteglobal.com/audi/rs3/8v.2-2.5-tfsi/317/tte777-evo-upgrade-turbocharger?number=TTE10316
#TTEGLOBAL
Congrats today to Mrc Tuning Scotland at Crail raceway
RS3 TTE777 Managed a 1/4mile pass of 9.6 @153mph not even on a correct tune as never had time to custom calibrate so still using a previous GTX hybrid tune and has overboost issues now on the TTE777.
Certainly more in the car once it’s custom-tuned
#TTEPOWER #RUNTTE #TTE777
100-200 BETA TEST
VW GOLF 7RS TTE777
99 Ron & octane booster
MRC software @2.2bar peak boost
Quick spool & huge power at moderate boost.
758HP 866Nm (full spool before 3500rpm)
E85 tune soon..
#TTE777 #TTEPOWER
That's a deeply impressive engine. Sounds great too.
What are the mods?
Nick
What are the mods?
Nick
RD Built motor
Custom inlet manifold
Forge turbo elbow
DML intercooler
TTE777
lpfp
980cc MPI injectors
99 octane booster NF
WMI
Milltek exhaust possibly..
about all i know
DVX Our partners in Belgium produced a great result.
Audi RS3 2.5 TFSi DAZA 400 HP @ DVX 724 HP / 867 NM
✅ 324 HP↗
✅ 387 Nm↗
Stage 4:
- Forged Engine (piston & rods)
- TTE777 Turbo
- Wagner Upgrade Intercooler
- Milltek duel 80mm downpipe & Turboback exhaust
- IE Air intake
- Forge Turbo silicon inlet
- Sharp-Motorsport Upgrade injectors
- WMI stage 2 kit
- DVX outlet pipe
Custom DVX performance Belgium Engine Remap 98 octane fuel with WMI @2.3 bar peak.
Custom DVX DQ500 Remap
Audi RS3 DAZA TTE777
DVX 653.3 HP / 778.0 Nm
✅ 253.3 HP↗
✅ 298 Nm↗
Stage 3 TTE777:
- TheTurboEngineers TTE777 turbo
- Sharp- Motorsport upgrade injectors
- Integrated Engineering Air intake
- Milltek Sport decat downpipe
- Forge Motorsport intercooler
- Forge turbo inlet
- DVX Outlet pipe
- 98 ron
- Custom DVX performance Engine Remap
Power Limited by stock engine & stock RS exhaust.
- Custom DVX DQ500 Remap
✔Increased torque limiter
✔Raised clamp force
✔Faster shiftspeed
✔Increased rpm
#RUNTTE
Reactions: HM3P
GOLF 7R 2.5 tfsi Daza with our TTE777 hybrid turbo on the dyno at SAR Turbotechnik
MTR Performance software.
VERY LITTLE LAG..... PERFECT DAILY PERFORMANCE.
900nm at 3500RPM
500nm at 2600RPM
(Approx)
807ps 968Nm
2.2 bar E50 fuel
#TTE777
Turbo info : https://tteglobal.com/audi/rs3/8v.2-2.5-tfsi-daza-dnwa/317/tte777-evo-2.5tfsi-upgrade-turbocharger?number=TTE10316.3
Reactions: Kondax
I know most people perform turbo tuning with bolt-on modifications like intake, turbo, intercooler & exhaust etc for good reason.
But does anyone use traditional, internal methods like big valves, ported heads etc? How do they get on?
Thanks, Nick
Sure most of the big frame turbo builds in USA are using cnc ported head and bigger valves, bigger inlet manifold, flap deleted runners, throttle and so on for improved flow.
NEW TTE777 WORLD RECORD 100-200
World’s fastest TT RS with TTE777 turbo
and Unitronic Stage 3 – E85
!! Europeans fastest TT RS with and hybrid turbo !!
Congrats Nardocar
and Claus L
We do not quite know if there are other records than 100-200 km/h.
If you know let us know
Times:
0-100km/h = 2,52 sec
0-200km/h = 6,53 sec
100-200km/h = 3,97 sec
200-250km/h = 3,49 sec
1/8 mile = 6,17 sec
1/4 mile = 9,43 sec (Missed a gear at the end of the run..will reset soon)
New world record turbo for a hybrid turbo on 2.5TFSI
And the first 5-cylinder AUDI to run in 8 seconds with a hybrid turbo & the fastest Audi in Canada
TTE777
Turbo & Unironic software
0-60 mph 1,91 sec
0-200 km/h. 5,74 sec
100 - 200 km/h. 3,69 sec
60-130 mph. 4.27 sec
1/8 mile 5.70@123 mph
1/4 mile 8,87@156mph
