dazza209
Hi I am new to the forum and after some confirmation that i have the right tools and procedure.
I am in the process of changing these but have hit a few snags,
1. how to release the electronic device ignorer to push calliper piston back, checked youtube found one that showed it being done if you had a laptop and software but then after picking myself up found one that showed you by removing the electric motor and winding the shaft and then pushing the piston back. Tried this and it works.
2. Had to buy 2x types of disc as unable to distinguish which i needed, size difference.
3. Need a special tool split drive I believe have bought a set from amazon m14.
4. TRW pads was supplied with the mintex version but are wrong so have to change for the Lucas one's
If anyone has done this job before can you confirm the way I am doing it is correct.
thanks.
thanks.
