Rear diff
Adrian mccoll
cant seem to find the part number for rear diff oil on the s3 8l
Looked online but somewhat confused myself...
Anyone know the part number and quantity ?
What oil you after? the actual diff oil or the haldex oil?
Diff oil tuffty, I’ve done the haldex and filter but want to do gearbox/front diff in which I have 3 litres of G052171A2
But I’m unsure of which oil code for rear diff?
Gearbox and rear diff will need different oil dude... gearbox needs a GL4 spec while rear diff needs GL5 spec...
I have used Comma 75W90 in my box..
https://www.gsfcarparts.com/980aa2740
And have some Fuchs Titan Sintofluid 75W80 GL5 spec stuff I have lying about from when I was going to fit a replacement diff
Yeah the oil I have for gearbox is from TPS and checked part number against 7zap
But on 7zap there’s 2 potential part numbers for original diff oil ? Like in my photos attached ? I think it’s G052145S2
Just need someone to confirm and tell me how much quantity is needed ?
G052145S2 is correct and it takes just over 1ltr
Before you drain it check you can undo the filler plug!, don't use a torque setting to tighten the plugs do it by feel
