Can someone confirm that you need vcds to enable this menu on the A1? Apparently can activate this on an A4 with Carista, but A1s software doesn’t give that option?
Copy the contents from the Green Menu Activation.zip to an empty SD card smaller than 32GB in size, formatted in FAT32 file system. In the root folder of the SD card you should see the following files and directories:
Insert in the MMI SD slot 1, shortly after that you will see the following picture.
Press the big rotary knob and the next screen will appear.
