Audi Bluetooth Module.
J0N
Can anyone point me in the right direction for coding an OEM Bluetooth module into a Symphony 2+?
Depends on the car and options, but I'm guesisng as you have a 2+ then you MUST have a multi function steering wheel to control the phone kit.
Then the coding changes depending on the car model
Reactions: J0N
2009 S3 8P with MFSW. I understand there are check boxes for Telephone in Radio and Can Gateway and then some coding??
BT Module coding
0011422 would be for nav unit, A3 and MFSW
0001222 would be for symphony, A3 and MFSW
And yes you should check the box in the can gateway to say you have a BT module installed
Also you can code the radio to add telephone option
Can't remember on an A3 if you need to code the steering wheel controller also, it's been a while
All of these things come up in the coding helper when using VCDS to code.
Reactions: J0N
Thanks for that Craig. It’s should be here tomorrow, I might be giving you a shout haha...
Fitted it today and it works brilliantly using the code provided by Craig. My only gripe is the connection / disconnection chime, it’s loud...really loud??
Sorted the connection chime, thankfully before it made my tinnitus any worse!
