TeaMonsta
It's always been quite difficult to detach the nozzle from my Karcher K4 pressure washer but never a problem to attach the foam lance. All of a sudden, I just can't get it to attach. I'm baffled. Any ideas?
Thanks, X3man. Do you mean the spring mechanism in the end of the hose that's attached to the washer? The one which you attach the two detachable nozzles to shown in the picture (or your foam lance)? It's as if the spring mechanism in the end of this hose (attached to the washer) won't compress enough to get my foam lance attached with its bayonet fitting. Could I still attach the foam lance to the quick release nozzle you've suggested?Sounds like you might have an issue with the spring mechanism.....get rid of the Karcher Lance....
That's exactly the reason I ordered the quick trigger gun from Imran.Sounds like you might have an issue with the spring mechanism. To be honest, best thing you can do is get rid of the Karcher Lance, and go for one of the quick trigger guns in2detailing do. Comes with the required quick release to convert your S/F, and all for under £35
https://www.in2detailing.co.uk/karc...-with-quick-release-nozzles-kar190635748.html
Best upgrade![]()
Mine arrived today, very impressed with it View attachment 189175
