2.0tdi to 1.9tdi swap
Satanslilhelper
Cornwall
Hi everyone, any B7 gurus out there? I have a B7 avant 2.0tdi (BLB)with oil pump failure, pretty sure it's toast. I also have a b6 1.9 tdi(AWX) and I'd like to fit this to the avant. Any ideas on what the best way to proceed with this? Will I have to change engine / loom/ clocks and if I do will it even work? Has anyone done this conversion before? Any ideas would be appreciated, thanks
Deffo need to do the ecu which in turn means you'll have to change the clocks.
I wonder if you could just change the actual engine block and head
Sent from my SM-G930F using Tapatalk
Just changing the block would be ideal if that would work! Not sure though as the blb is 16v and the awx 8v. I would have thought the heads would be externally different but I'm not sure
Change the engine block with head on
