EctoA3
Surrey
Hi All,
I've got a 2.0tfsi (ccza) 3dr a3. 09 reg, 115k miles.
Had the clutch and flywheel replaced (used sachs parts).
All seemed fine but 30 miles after picking the car up I was driving down the m4 and the EPC light came on aswell as the engine warning light, and the car went into limp mode. For a few hours after this, the car was struggling to start, hot or cold. (Starter motor would engage but take a few seconds for the engine to fire up). After a few hours, the car jumped to life straight away and the EPC light went off, as did the engine warning light.
The car then started normally (instantly) and had no further issues for another 200 miles. Immediately after the epc incident I had the mechanic look at the car again but couldn't find any faults.
However, the EPC light then returned.
This time, the car was taking it's time to start, but once the RPM had dropped from the initial 1100, to 800ish (so about 45 secs after starting the car) you could turn the engine off and restart it without issue or EPC light.
Today, took my foot off the accelerator whilst going down a dual carriageway and the car jolted, epc light engine light combo returned and yet again sent me into limp mode. Even when hot, it is struggling to start.
Any thoughts?
This all started when the clutch and flywheel were replaced, I never had any issues before. (Work was done via gearbox removal)
Apologies for the ramblings but I wanted to include as much detail as possible.
check earth to gearbox epc is normaly throttle cruise control but if the clutch was replaced i would go for earth lead of or loose
Thanks mate, any more thoughts anyone?
Going to print off this thread for the mechanic
Update, the engine won't go above 3800 rpm.
