Help Please Sat Nav issues
WozzaAK
Slough
Hi guys I need some help. Who's the go to guy on this? The car is S4 B8 saloon.
I'm currently trying to get the sat nav working which shows no satellites. It has a shark fin antenna which turns out has broken connections in headliner. I've stripped it back to c pillars & removed both fakra connections on either side. My plan was to use a hockey puck antenna. But once I removed the head unit (cd changer) I cannot see the fakra connection on stereo or the fakra connection on the loom anywhere.
My system appears to be bang & olufson, cd changer, ami usb in glove, centre console with all the buttons & mmi screen, shark fin antenna with 2 connections. I'm not totally sure if some or all of these bits are original or have been retrofitted later. I've only had the car 2 weeks.
I'd appreciate any help.
I ain't got a clue dude. I need to speak with someone who knows this setup. I can strip parts if necessary just need advice.
Hi,
This might sound like a daft fix but has the power to the head unit in the middle of the dash (where the SD/CD's go in) been disconnected at any point? I ask because I had the exact same issue and unplugging the Quadlock connector on the back of the unit and reconnecting sorted the issue for me.
Thanks,
Matt.
The GPS connector on the back of the head unit is the blue Fakra. There is a universal colour code for Fakra connectors, GPS is blue.
I've disconnected the & reconnected a few times. I want to bypass the factory fakra connection but can only find the connection in the c pillar at the rear of car & no fakra connections at the front of car.
Yes I know but theres no fakra connection at the back of head unit. There is a shark fin antenna & fakra connections at the c pillar at the rear. This is whats confusing me, where is the fakra connection on the factory loom at the front & why does the cd changer not have a fakra connection on the back of head unit. It's possible that previous owner has tried to retrofit the mmi system & has not completed it.
I need to speak with someone who knows this system in & out. Anyone know the best person to speak to? Thanks for ur help guys
Do you know what system you have? It might be MMI 2G in which case the sat nav module is in the boot on the passenger side.
Hi I checked earlier & yes the sat nav module & multimedia player is in the boot. Will i find the fakra connection there? I want to bypass sharkfin antenna & use hockey puck as a temp fix just to get the nav up & running. Thanks
yes, there should be a blue fakra connector on the back of the navigation module
Ok thanks a lot.
By the way would u know where the single brown spade connection from behind climate control goes. I cant find anywhere it should connect.
20190629 183259
Probably the earth for the cd changer.
Ok will check the head unit. I bypassed the sat nav antenna & its all working now. But I must've loosened a connection on the B&0 system in the boot as all the bass has gone. Will check this later, thanks for ur help
688
680
NHN
NHN
