How much modification is needed to make an aftermarket exhaust from an s3 saloon fit a 3 door hatchback?
So in theory could just take off the tips, chop off 5 inches from the back and reattach the tipsWell, 144mm.
I have an S3. Someone is selling a bcs powervalve exhaust from a saloon and I was wondering if I'd fit my hatchback without too much hassle.Is your hatchback A3 or S3? The S3 exhaust is much thicker than the A3 one, perhaps double as thick and there is not enough place under an A3 trunk for a S3 back box. You could modify the mounting brackets, but the muffler would hang closer to the ground.
As to the pipes, I suppose that if you cut the Saloon pipes, you would have to bend them slightly outwards in order they to fit the cutouts in a diffuser.
Mind me asking why do you need it?
I looked at pictures of the bcs exhaust online. It looks like the tips are a clamp/weld on? You could take the tips off and cut the pipes, then refit the tips. It should work.I have an S3. Someone is selling a bcs powervalve exhaust from a saloon and I was wondering if I'd fit my hatchback without too much hassle.
