Hello guys, new account but I've been lurking around here for quite a while.
Wanted to ask about the old and tried question of the RS grille and better headlamps. Hopefully this can also be helpful for other people as a bunch of the other threads that I found were very old.
I looked at the following guide and unfortunately the pictures on it are expired.
https://www.audi-sport.net/xf/threa...eplace-your-front-grille-facelift-8p3.174559/
Regarding the guide, I wanted to ask specifically about Step 6 as I can't quite visualise the following statement
".... Remove the radiator cover from the rear of the grille highlighted below. You will need to drill all the plastic sections (circled) so that it can come away from the grille."
Is anybody able to picture the sections that will need drilling through? It would be a big help.
Now, my Audi is a 2010 A3-3P S-line, and from what I have been reading the RS grille should just come on without any fiddling necessary. But just wanted to make sure, I am planning on buying the following one:
https://preview.tinyurl.com/yxfjls8e
Would this require any additonal work? I asked the seller already and he said no, but I want to make double double sure.
Regarding the headlamps, I am planning on getting those, the original plan was to just replace a broken passenger side headlamp, but seeing as the bumper has to come off for that anyway and the standard lamp costs around £120 I decided to go all in and just redo the front end:
https://preview.tinyurl.com/y44df7s2
From what I saw in the following video, and the comment section, it seems like its a straight swap without any additional cabling required, but again, I want to double double check. I don't think I will need washers either as they are not xenons, but simply halogens with projectors, is that correct to assume?
Also, the seller states they are legal, so they should hopefully not be blinding to other people and will pass MOT?
Thank you for any answers, and sorry for grinding this topic again.
Here are a couple of pictures of my car, if anyone cares for a 1.6 TDI A3 that is haha.
https://imgur.com/mcw6SVC
https://imgur.com/pvR6hco
