Cam Shaft Position Sensor help
JamesW1994
Isle of Man
Any guru’s know where to start with this one? Symptoms... Car bucks / jerks around 1 - 3k RPM occasionally, almost feels like a misfire but no codes for misfires at all. Its very noticeable. Past 3k always runs perfect. This has been happening a while but took some time for this code to appear. Thanks in advance :)
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 116588 km
Time Indication: 0
Date: 2019.04.24
Time: 18:39:27
Freeze Frame:
RPM: 1336 /min
Load: 21.2 %
Speed: 31.0 km/h
Temperature: 30.0°C
Temperature: 11.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.351 V
Camshaft position is hydrolic, check oil level/oil pressure, pick up pipe etc also check wiring connection /plug to the position censor.
Clear fault code and see if it comes back, as its only faulted once it may be nothing to do with your problem.
