Best snowfoam and pressure washer?
Joxh
Wakefield
Just wondering what everyone uses for their car. I don't have proper pressure washer setup and I am wanting to get one just for the car. Can anyone recommend a fairly cheap setup that does the job. Thanks.
I have one of these was cheap deal at Halfords (£100 I think I paid £80) does the job, only downside is the short pressure hose need to move the unit around a few times to get the whole car .... There are other versions that have attachments for doing decking and other wooden surfaces paving etc.
Karcher K2
www.halfords.com/motoring/car-cleaning/pressure-washers-hoses/karcher-k2-full-control-car-pressure-washer
362475
I use this stuff as I have a ceramic coat PH neutral 150ml in the .5L and let it soak for a bit and wash it off by hand
Valet Pro pH neutral snow foam
www.amazon.co.uk/gp/product/B005JN5V5M/ref=ppx_yo_dt_b_asin_title_o08_s01?ie=UTF8&psc=1
Unknown
I'm sure there is loads in the detailing forum, I can never keep mine clean for more than 1 Hr. I live in the country side...... and am by no means an expert...
https://www.audi-sport.net/xf/forums/detailing.116/
Reactions: Joxh and shaunwo01
If your just starting out, I’d recommend going cheap and cheerful to get you on your way.
I find Demon Snow Foam (Halfrauds, other shops available) is actually pretty decent stuff at that price point.
I actually use it with my pressure washer, however they do a version that you can just connect to a regular hosepipe.
Cost is around £12.:racer:
Reactions: Joxh
In2detailing do snowfoam lance kits mate very good value for money
K4 is your best bet refurbished around £100
Reactions: Joxh and Scotty75
I just use Citrus Prewash - works well. I was a bit concerned about hosing all the foam down the road to the drain.
How eco is this?
Reactions: Joxh
Got to agree with this . Snowfoam Lance from In2detailing cost me £16 and works great. Karcher k4 cost me £159 and so far it's brilliant. Vario Lance for bodywork , jet Lance for wheel arches.
Valet Pro is good snowfoam but I'm using TAC Systems Ultra snowfoam at the moment and that's really good too.
Sent from my Nokia 8 using Tapatalk
Reactions: NevMan and Joxh
Don't forget the car nozzle , some people have found the clear coat coming off wheels etc when using the normal patio cleaning nozzle. Amazon do a Nilfisk 'Auto nozzle for pressure washer' which I have and been brilliant so far.
Reactions: Joxh
That's what the Vario Lance is for as you can control the jet so it's not too harsh .
For cleaning power bilt hamber auto foam takes some beating. Doesn’t produce the thickest foam but it does clean a lot of the muck off and definitely loosens it for jetwashing off. You can also use it through a pump sprayer with hot water. This is what I do in the winter and it’s not far off a touchless wash if you have decent protection already on your car. I only use the foam when it’s warmer as it can dry fairly quickly using a pump sprayer. Needs to dwell for around 5 minutes for best results. Another option is spray BH AF on with a pump sprayer for its cleaning power and cover it with a cheap foam to stop it drying out so quick in the sun.
Definitely worth checking the karcher outlet. Buy the best you can afford K4 or better would be my choice. Only use the vario lance on your car, don’t go near it with any other attachment!
https://www.in2detailing.co.uk/products/wash/snow-foam-and-lances/bilt-hamber-auto-foam-5-litre.html
Reactions: Joxh
K2 Karcher plus Autobrite foam lance using Meguiars Hyperwash snowfoam.
Citrus pre wash prior and Fireball Easycoat afterwards.
Reactions: musicegbdf, Jassyo06 and Joxh
Been watching this thread.
I have a k2 and it’s starting to break after about 7 or so years. Started leaking from inside so thought it’s time to upgrade.
For those with the k4 is there any point in the variable nozzle control thing? Is it just a gimmick?
Reactions: Audi Bairn
@Joxh - Another vote for the Karcher K4 here
I was lucky enough to get a new one from Asda for £100
Best place to start looking would be Karcher's Outlet Store
https://www.karcheroutlet.co.uk/products/product.asp?id=5599
Don't forget to check out Amazon's specials on Nilfisk power washers, especially over the easter weekend
Snow foam lance ?
Can't beat Autobrite's IMHO
You may pay a little more but they are the best
https://www.autobritedirect.co.uk/exterior-cleaning/hd-foam-lance-and-snow-foams/autobrite-heavy-duty-foam-snow-foam-lance-and-magifoam-500ml/ad-foamlance-magi-500ml-karcher-kseries
Snow foam? I'm not a fan but if you must Bilt Hambers Auto-Foam is highly recommended
https://www.polishedbliss.co.uk/bilt-hamber-auto-foam
You'll find with Car Detailing that everyone has their own fave products. Its just a matter of trial and error to get what works best for you
Snow foam lance ?
K5 Premium here, but K4 very good
+1 for the autobrite Lance, have had mine for 5+ years no issues and used a lot
Reactions: Bristle Hound
And the BH foam Also, AngelWax Cleanliness is ace too
Good thing about the auto brite Lance is it is easy to take apart and remove the gauze capsule soak over night in vinegar and rinse . The lance will foam like new again . You can also by a new capsule for £5 .
I like their foam as well
Reactions: NevMan and Audi Bairn
I’ve been using the tj’s snowfoam with my crappy k2 I need to upgrade the pressure washer
You get the variable nozzle on the new K2, if I’m understanding you correctly. It adjusts for different uses, eg cars, drives etc.
The K2 nozzle is adjusted manually by twisting it, no leds though.
Same happened to my old K2 as yours but only after 13 or 14 years so I got my money’s worth
I got mine free when I bought Tesco insurance years ago. Definitely got my money’s worth too. :thumbs up:
It still works but it’s leaking a tiny bit from somewhere underneath so when I leave it on it powers up every few seconds which is annoying the **** out of when when I’m like scrubbing the wheels or doing something other than using it.
Time to put it to rest I think.
Just need to make sure the connections are the same in the new ones as I have the extended 12m hose and snow foam gun etc.
Really? Haven’t done any of this on mine, tend to rinse off after use. Didn’t even know there was a capsule
Yes it is like wire gauze . This creates the foaming of the solution . Over time it gets clogged with soap residue and you get less and less foaming . With the karcher gun you have to buy a new gun . With autobrite ( and others made by the Italian factory) you can open it up ( nice brass fittings) soak it to clean out the soap and as good as new . Will try to upload a picture.
Didn’t know this either mate, cheers for the info :thumbs up:
Glad to help , I have had plenty of good advice over the years , so nice to return the favour.
if you go on the karcher website refurbed k2 under £100 with an option of extended warranty
i use pro kleen snow foam does the job but there is better on the market will try valet pro once ive used 10 litres
for £20 or 15 for £25
Can only commend on my current set up which is a Nilfisk washer and Bilt Hamber snow foam.....highly recommend both :icon thumright:
Amazon doing Karcher K4 for £159:
Kärcher K4 Full Control Pressure Washer Amazon product
Well spoke too soon. My k2 has finally given up. It just sprays water from underneath and power stays on.
Anyone here who’s had the k2 and k4 confirm if the accessories connections is the same?
Is the k4 much more powerful than the k2? My k2 is a bit crap
I think you only really need a more powerful one for cleaning patios and drives etc. I would think that even the bottom of the range would be fine for car cleaning.
Not sure about the snow foam aspect though as I don’t use that - I find citrus prewash does the job fine.
