Hi guys
I know there's already quite a few threads on this common fault, but wanted to see if anyone could give me a steer as I'm hoping to get my aircon working on my A3 2005.
As I understand it the ECON button staying on means there's a problem activating the system which could be re gas, pressure switch, compressor.. etc. Before I try a regas, I have the following errors appearing on VAGCOM scan -
01592 Air Quality Sensor Open or Short to Plus
01809 Left Temperature Flap Positioning Motor Mechanical Failure
Questions I'm wondering are:
Any help much appreciated !
- Could either of these above issues be causing the ECON light error? (Ie should I investigate these before doing the re-gas, or is the re-gas/low pressure still a likely cause?)
- Also I've read that one cause can be a broken G65 pressure sensor. If this was the case would that fault show up here on the scan?
