Hi,
I retrofitted a MIB2 High (8v1 035 035) unit into my PFL A3(factory fitted with MIB1 High, TSR, ACC with dome radar, Lane Assist,) , all works fine except some issue with Traffic Sign Recognition. Shortly after engine startup I get "Traffic Sign Recognition: Currently Restricted"-with the MIB1 unit I rarely seen that message-, but sign recognition appears to still work and I get posted speed limits on my instrument cluster. This is why I assume it's an issue with VZO setings.
I also get this error on module A5, it reappears as soon as I clear it :
If I disable TSR from A5 coding, the error is gone. On module 5F: I tried disabling/enabling VZO, different settings for Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus, but no luck getting rid of that error.
I noticed that the A5 controller has a coding byte for MIB1/MIB2, but my unit doesn't accept changing the coding to any of the MIB2 settings(I tried with Ignition On/Engine Off).
To get rid of that error, do I need to update the A5 firmware or is just some coding/adaptation issue? I noticed there's a 5Q0980653G H06 0060(mine's 5Q0980653E H05 0050) firmware available. Can I use this firmware on my module? Can this update affect ACC or any other front assist system? I know that I need to use VCP to parameterize the module afterwards. Calibration settings I assume I can just import my current calibration settings.
Any help is welcome!
Thanks!
1 Fault Found:
2555904 - Databus
U1121 00 [009] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 22
Mileage: 162496 km
Date: 2019.02.27
Time: 10:40:13
Control Module temperature: 39 °C
Outside air temperature: 6.5 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 12.3 V
Terminal 15 on: 131.5 s
Thanks!
