8v calipers to 8p
ch1z64
C'mon you's bhoy's in Green
Kilwinning Ayrshire
Has anyone tried to fit these yet as I can get a hold off all four but not sure if they will fit my 8p any advice appreciated , not looking for yip they can more looking for definitely they can but you have to do this ? . Thanks in advance
I’ve just fitted these to the fronts. Works great.
I am assuming these are on an 8P and 18"alloys sit fine over the top off them as I have brembo discs and 18"
Yes, I have an a3 8p 2010 sportback. These calipers came off an s3 8v 2015. Running 18” s line wheels and plenty of room.
Cheers mate now all I need to do is find out the price for the 8v ones
I’ve only had these fitted a week and I paid
Front pair of calipers £180
340mm Discs £105
Pads £40
Brake lines £45
Hope that helps
Reactions: Mr_Dude
340mm Discs £105
Pads £40
Brake lines £45
Hope that helps
Did you have to get new carriers?
340mm Discs £105
Pads £40
Brake lines £45
Hope that helps
That will mate , hopefully my brembo's should be alright and pads ( textar )
I will try and grab a picture in tomorrow with them sitting behind the wheel
You'll need the 8v rotors apparently.
To go with 8v brakes
Sent from my highchair using Tapacar
Hey Jay, were the carriers matching up to original hubs or did you use 8P carriers, so were they pnp, bolt on.
I've got some new uprated front S3 8P lines to fit, but would if I'm swapping to S3 8V from S3 8P fronts, may have to get new lines too, I'll check that.
Assume you had to use 8V discs?
340mm Discs £105
Pads £40
Brake lines £45
Hope that helps
Nice upgrade :)
You have the partnumbers?
Thanks a lot
Enviado do meu iPhone usando o Tapatalk
Did you use the 8V carriers as bolt on or needed adaption.
Reactions: Mr_Dude
