Hi all
Hoping someone out there can help, have done an engine swap on an Audi a3 16v TDI BKD. The car started after the swap but is generating the following fault code below. After clearing the codes came straight back have checked the wiring seems all OK also used the original wiring loom from the old engine.
6 Faults Found:
16706 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal
17036 - Sensor Reference Voltage B
P0652 - 000 - Too Low
17903 - Switch-Over Valve for EGR Cooler (N345)
P1495 - 000 - Open or Short to Ground
16627 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 000 - Malfunction
16567 - Fuel Temp. Sensor A (G81)
P0183 - 000 - Open or Short to Plus
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
6 Faults Found:
